Stuart Restoration
Stuart Restoration
Home Forums Stationary engines Stuart Restoration
Viewing 7 posts - 26 through 32 (of 32 total)
  • #811860
      3D printing has certainly changed many of the various types of modeling from figures to AFVs to cars/planes. You look to have got the scale about right to go with the “workshop” engines which were never massive.
      Oh and just to further confirm that the  “sticky out” bits are correct even Stuarts offered them as castings for their slightly larger dynamo. The same arrangement is still used today on large electric motors to tension Vee belts. You also need flexible wiring to allow for the adjustment they give not rigid bars or conduit.
      stick out
      Nicholas Farr
        @nicholasfarr14254
        Hi, well I like it a lot, yes the switch did look out of place, but the addition of the spares box has really overcome that problem. Well done Richard.
        Regards Nick.
        #811862
        Nicholas Farr
          @nicholasfarr14254
          Hi, the sliding runners shown in JasonB’s photo above are still used today, but in the picture, the one on the belt/chain side, should be the opposite way round to the other side, this is so that adjustment can be put on to the dynamo or motor on that side, and the opposite side will counteract the twisting effect of the belt/chain during the adjustment, and during loading in use. In industry, machines always seem to have sticky out bits.
          Regards Nick.
          #811863
          Charles Lamont
            @charleslamont71117
            Well, I think you have done an excellent job of restoration and presentation. Thank you for taking the trouble to post it. This forum would be more interesting if more of us showed our work.
            #811870
            Richard Simpson
              @richardsimpson88330
              Many thanks for the comments gents.  I eventually decided on a scale of 1/19th for the figures.  I think there is a fair degree of leeway but I thought 16mm was a reasonable size to give the engines an imposing feel while still having a large enough figure for detailed painting.  Doll’s house figures would have looked too big and been in danger of becoming the subject.
              #811878
              martin haysom
                @martinhaysom48469
                On cogdobbler Said:
                On SillyOldDuffer Said:
                Excellent, just what I like with my breakfast coffee.  Hard to date, could have been made almost any time in the 20th Century because Stuart have been going for donkeys years.  Ditto Meccano, who provided the chain and sprocket wheels.
                May I suggest three minor improvements, replacing parts out of character with the rest.  Nothing difficult, and they offend my eye!
                improvements
                The switch at arrow ‘A’ is clearly designed for human fingers, and its scale is wrong for the model.  And the d*mn thing being bright and shiny catches the eye.    Nothing that size and shape existed in an engine house!  Could be hidden round the back or replaced with a simple home-made brass knife switch scaled to match the man.
                The plastic twin cable connected to the dynamo is also a bit out of place, though only a pendant might notice!   First, wiring is never run at anything other than a right-angle, so drop it straight down to a new hole in the floor.   Second, plastic insulated wire could be replaced with shiny brass strip or thick copper wire.   Both look more like the open busbars found in early electrical installations, and would match the look of the steam installation.
                The way the dynamo is fixed to the floor looks odd to me.  No Aluminium in early engine rooms!   The sticky out feet are unnecessary and the mounting seems over-complicated.  Might be a poor implementation – an old dynamo I saw in Wales had a similar arrangement, except it the slim Aluminium in the model was replaced by a hefty balk of timber, a good way of reducing vibration on the cheap.  I’d be happier if the model dynamo were bolted straight to the floor, or the Aluminium was disappeared by painting it black!
                Sorry to be a fuss-pot, but minor anachronisms stand out in a first-class job!
                OMG, I’ve turned into Inspector Meticulous.  Nurse, where’s my medication…
                And you wonder why model engineering (and this site) is failing to attract new blood. Prime example right here of the type of armchair nitpicking and negativity that has not only discouraged newcomers but also driven away many of the old hands.
                well said
                #811887
                parovoz
                  @parovoz
                  Lovely job. You turned an old and much neglected model into a real exhibition piece. And I like the tool box trick…. The last wee details just elevated the whole thing. Super work, and I do like the figures. And I agree, much better than ‘dolls house’ the realism just adds to the whole effect.
                  Thanks for sharing.
                Home Forums Stationary engines Topics
