Stuart 800 Gas Engine
Home › Forums › I/C Engines › Stuart 800 Gas Engine
  • #96768
    Maurice Cox 1
      @mauricecox1
      Hi there,
      Has anyone out there had any experience of building a Stuart Turner 800 gas engine please? I am helping a friend with his, and the drawings leave much to be desired. The current problem is with the casting that carries the gas and the air valves. Some of the dimensions are taken from the edges of holes, and are contradictory. Others just seem completely wrong. I would welcome any help, as I dont want to "guess" on someone elses project. Thanks a lot.
      Maurice Cox
      #2346
      Maurice Cox 1
        @mauricecox1
        Drawing errors
        #96780
        MichaelR
          @michaelr
          Hi.
          This video shows a Stuart 800 running, the person who made the engine my be able to help you should be able to get in touch with him through his Youtube profile.
          <iframe width="480" height="360" src="**LINK**" frameborder="0" allowfullscreen></iframe>
          #96972
          Maurice Cox 1
            @mauricecox1
            Thanks for the link to the video. It certainly looks a fine engine, and has encouraged me to persevere with the one I have in hand.
            #98984
            Colin Carey
              @colincarey61337
              Hi Maurice,
              I'm starting a project scratch building a gas engine using the Stuart Turner 800 as a basis for the design purely based on photos I've found and the odd description, do you know where I can obtain plans for the the Stuart 800, I'm especially interested in the Exahust, Inlet & Gas valve configuration ?
              Thanks
              Colin
              #215973
              David Cambridge
                @davidcambridge45658
                An old thread to resurrect, bit I have the same question as Colin. Does anyone know where the plans for the Stuart 800 can be obtained ? Otherwise, I can try some of the youtube builders as suggested above.
                David
                #215977
                  So you getting a set cast then? What happened about the Amanco
                  #215981
                  David Cambridge
                    At the moment it’s curiosity – I like the idea of the side shaft and fly ball governor and I’d like to understand more about how it all goes together.
                    (Jason – Amanco ?)
                    #215982
                      Sorry I was getting you confused with another David with a county as his surname who had the offer of using somebodys patterns to make an 800.
                      PM about to be sent
                    Home › Forums › I/C Engines › Topics
