Stiff lever deckel FP1
Home › Forums › General Questions › Stiff lever deckel FP1
  • #128615
    Robonthemoor
      @robonthemoor
      Stiff low high table lever
      My deckel FP1 as two lower levers on the right side, to operate the X & Z axis, the front one nearest the table as two positions, but it is stiff to move? If I loosen the case it go's easy! Take it all off" & its all as free as a bird. But when I fit the case cover back on and tighten it up the lever is very stiff! Do I need to put a thicker gasket on.
      Rob
      #22808
      Robonthemoor
        @robonthemoor
        #128650
        Robonthemoor
          @robonthemoor
          All sorted,I found an adjuster just below the lever.
