Step chuck modification
Home › Forums › Workshop Tools and Tooling › Step chuck modification
  • #19854
    Plasma
      @plasma
      #484206
      Plasma
        @plasma
        Hi all.
        I've had a smart and brown model L headstock laying about for a long time, with half a plan to use the step chuck on my Boxford lathe.
        I finally got round to modifying a mounting plate for it, which is a D-1 3 mount.
        I had to cut off the end of the hardened steel spindle to use and machine a backplate to suit. I didn't fancy my chances at making a backplate with suitable spindle nose thread. Plus it will only see occasional light use so I didn't need to make something so involved.
        It was a relatively straight forward job but cutting the spindle was the hardest part, I used a disc grinder with the spindle rotating slowly in a very well covered lathe.
        I can now use my s&b collects and the step chuck On either of my Boxford lathes for thin piece work etc.
        #484217
        Phil P
          @philp
          It is nice when all your work holding gear fits multiple machines.
          I also try and use the same collets etc, on my dividing heads and rotary tables.
          Phil
          #484221
          Martin Connelly
            @martinconnelly55370
            Did you have to make a draw bar or draw tube to go with the collets or is there something else closing the collets?
            I have a step chuck and a cone chuck. They are rarely used because they usually don't fit what I have to hold. I think there were 3 sizes in a set of each and I only have one of each. I find soft jaws in a 3 jaw chuck more useful.
            Martin C
            #484352
            old mart
              @oldmart
              I have bought several of both types of step collets for the museum's model A, including one from this firm, they had two, but they were both the same size.
              Plasma
                @plasma
                I have a set of four step collects, each with different ranges. I will post the sizes tomorrow, they pretty much cover a fair range of sizes.
                I had the draw bar tube for the original lathe but it was a shade too short. So I made a small extension piece and fitted a spare handwheel so that it fits.
                I'm quite happy with it for thin piece work, I don't have any soft jaws so this will be just the job.
