Steel pins & linkages
Home › Forums › Beginners questions › Steel pins & linkages
  • #117990
    nigel jones 5
      @nigeljones5
      In building Invicya from 31/2 gauge scaled up to 71/4 plans. All the valve linkages are steel with steel pins. Im a bit concerned about steel on steel, any comments please?
      #6684
      nigel jones 5
        @nigeljones5
        #117993
        MICHAEL WILLIAMS
          @michaelwilliams41215
          Hi Fizzy ,
          Have you got a real name – calling you Fizzy all the time seems a bit discourteous !!!!
          Seriously – no problem with steel pins in steel links but for a sound job use pins which are both hard , true and well polished . Silver steel ' as is ' at a pinch but better hardened dowel pins or rollers from needle roller bearings .
          Pins often don't need much retention end wise – light press usually adequate .
          Finish in the hole that pin runs in is also important – ream to close fit on pin .
          Regards ,
          Michael Williams .
          Edited By MICHAEL WILLIAMS on 28/04/2013 12:13:34
          #118009
          nigel jones 5
            @nigeljones5
            Thanks Michael, for 'political' reasons i rather prefer not using my real name, anonimity is much prefered. I will crack on with the rest of the valve train!! Having a baby tomorrow so things might be on hold for a while!!
            #118026
            Stovepipe
              @stovepipe
              Posted by fizzy on 28/04/2013 15:48:57:
              Blimey, you will make your fortune – most of us leave it to the wife !
              Hope all goes well
              Dennis
              #118032
              Sub Mandrel
                @submandrel
                All the best for tomorrow!
                nigel jones 5
                  @nigeljones5
                  thanks chaps…
                  i wish i could lose my beer belly tomorrow but alas tis the missis!!
                  #118049
                  Springbok
                    @springbok
                    Hope all goese well let us know is it a boy or girl, All mine are granchildren in late teens or early 20s.
                    Bob
