Steel axleboxes
Steel axleboxes
Home › Forums › Beginners questions › Steel axleboxes
  • #427714
    Former Member
      @formermember19781
      #9844
      Former Member
        @formermember19781
        steel axleboxes
        #427715
          Being a bit darker than the steel parts I would say they are cast iron which will be OK
          #427716
          Former Member
            @formermember19781
            #427718
              With simple parts like that you hardly need castings, cut from CI bar would be about 1/4 the price.
              #427721
              Ron Laden
                @ronladen17547
                I dont know if its normal practice or not Bill but I have made mine from steel and a lot of locos I have seen both electric and steam have had steel ones.
                #427780
                Nigel Bennett
                  @nigelbennett69913
                  No problem at all with steel axleboxes with either gunmetal or cast iron horns, but they need to have a proper bearing for the axles. This could be with needle roller bearings or pressed-in bronze bushes.
                  You could even use steel horns with steel axleboxes, as the movement is slight, but you need to pay more attention to the lubrication.
                  Steel-on-steel does not work well as a rotating bearing as it's prone to "pick up" and seize.
