steam ports
steam ports
  • #302377
    Philip Burley
      @philipburley44197
      I am making an engine , 2 cylinders , 1 inch bore , The plan doesn't give the port to cylinder end drill sizes . Would 2 x 3mm drillings pass enough steam ? Then a rebate into cylinder end 3 x2 mm at each drilling ? not much room for anything bigger
      #32996
      Philip Burley
        @philipburley44197
        #302382
          What is the stroke, what is the inlet port size, is it just for display running or do you want it to do actual work, Wat is teh engine you have plans for?
          J
          Edited By JasonB on 13/06/2017 12:10:47
          #302433
          Philip Burley
            @philipburley44197
            its a 2 cylinder traction engine , cylinders 1inch x 2 inch , steam ports are 1/2 inch x I/8 inch . R,S and J engine
            #302435
              Two holes does sound a bit restrictive is there any chance of getting 3 x 3mm in?
              By way of comparrison my 2" Fowler has a 2" stroke but larger 1.375" bore which works out about double the area of your 1" bore and ports are double at 1" x 1/8" , that has six 1/8" holes, you do have to pack them in a bit tightly though.
              And another tightly spaced set of holes
              #302450
              Philip Burley
                @philipburley44197
                a bit limited by the stud holding the valve chest on , but might be able to open up the drillings to 3.5 mm
