Thank you.
The cabinet is their “blaliden” model:
https://www.ikea.com/gb/en/p/blaliden-glass-door-cabinet-black-00520519/
As discussed, it’s a bit wobbly without further support, and has a gap around the edge when the door is closed (easily filled with self-adhesive foam). It was also typical that neither of the top two shelf positions corresponded with where I wanted the movement, so I had to make some custom brackets that would pick up off both of the existing screw holes, but for £80 it was the best I could find on a reasonable budget.
