Stainless steel sheet
Home › Forums › Beginners questions › Stainless steel sheet
  • #57740
    David Costello
      @davidcostello75947
      I am looking for SS sheet in 16 or 18swg but can only find sheet in metric thickness,can anyone tell me what i would need.
      Thanks for your help
      David Costello
        @davidcostello75947
        #57742
        Nicholas Farr
          @nicholasfarr14254
          Hi Dave, 16 swg is just slightly bigger than 1.5mm, 18 swg is 1.2mm.
          Hope this helps.
          Regards Nick.
          #57744
          David Costello
            @davidcostello75947
            A very quick answer to my problem,
            Thanks Nick
            Sub Mandrel
              @submandrel
              I will be shouted at for this as it is far from accurate, but…
              16 swg is nearly 1/16″ which is nearly 1.6mm…
              And remember that as the swg gets bigger the number gets smaller.
              Anonymous
                I’m in pedant mode this afternoon. As the swg gets larger, the number gets larger; it’s the thickness (or should that be thinness) that gets smaller.
                #57880
                Weldsol
                  @weldsol
                  Mmmm, on a SWG (gauge) the hole gets larger as the number decreases
                  Paul
                  #60853
                  Nick sam
                    @nicksam29200
                    Not sure about the what sizes you want but you can check this website for all sizes of Stainless Steel Sheets anytime…
                    http://www.metal-supplies.com/8601/12805.html
                    Edited By Nick sam on 20/12/2010 10:03:50
                    #60866
                    David Costello
                      @davidcostello75947
                      And i thought Nick sorted my problem,whats all this ?
                      Dave.
                      #64456
                      Nick sam
                        @nicksam29200
                        okay david , we always with you to support any situation of being needful any help from us.
                        #65015
                        Claire Davenport
                          @clairedavenport92258
                          Try Contech they specialize in contract production of high precision stainless steel.You can visit their site at http://www.con-techinternational.com, they have contact numbers there for you to inquire.
                          Hope it helps.
