Square holes
Square holes
Home › Forums › Beginners questions › Square holes
  • #58514
    macmarch
      @macmarch
      Does anyone know which issue contains the details of constructing the attachment for drilling square holes?  I did start to look in the archive but it taking so long and there are a number of issues not listed.
      #5283
      macmarch
        @macmarch
        #58523
        John Baguley
          @johnbaguley78655
          Could be Volume 197, issue 4287? I don’t think the archive goes back that far though.
          Weary
            @weary
            2006, Vol:197, Issue 4285, page 493  ??
            How to drill square holes, author Jacques Maurel.
            Here is a searchable index if this is not the correct article.
            This series of postings covers the topic, and includes a number of postings from M. Maurel on the subject.
            M. Maurel has his own website here and posts videos on youtube.
            Edited By Weary on 10/11/2010 10:44:07
            Edited By Weary on 10/11/2010 10:48:10
            #58627
            Richard Parsons
              @richardparsons61721
              MacsMarch have a look at some of my pics.  On the surface plate in the top left is the thing described in the article
              Good luck
              #58635
              macmarch
                @macmarch
                No wonder I couldn’t find it, I don’t have a sub to M.E., only M.E.W.
                I have had a look at Weary’s links. Plenty to study there. Thanks Richard.  All I have to do now is make it.
                cheers all
                Ray
                #58685
                Richard Parsons
                  Macmarch – two tips.
                  The Warrington coupling inside it uses two ‘bearing plates that came from SKF are hard but thin. Rather than cut them as recommended I used a ‘cheapo’ diamond burr (fraise) and ground holes with my ancient Dremel. It did for the burr but it was worth it.!
                  The No2 MT was machined in the Myford using a taper turning attachment. If, when you make yours, and it sort of fits where it touches. machine away the center 1/3rd of the length.
