Spring Tapping Guide
Home › Forums › Workshop Tools and Tooling › Spring Tapping Guide
Viewing 15 posts - 1 through 15 (of 15 total)
  • #428844
    Vic
      @vic
      I have three of these and use them quite often but they have a common problem. They all have 1/2” bodies which is too large for one of the two smaller chucks I often like to use. Simple things I know but have any of you seen a drawing for a 10mm shank version to save me some time on the computer. TIA.
      #19462
      Vic
        @vic
        #428850
        Thor 🇳🇴
          @thor
          Hi Vic,
          Years ago I made a simple one with 10mm OD, there is a simple sketch at the end of this pdf.
          Thor
          #428859
          Vic
            @vic
            Thanks for that Thor.
            #428875
            Howard Lewis
              @howardlewis46836
              Could you turn down the OD of the shank, for as far as possible (without breaking into the innards )?
              #428896
              not done it yet
                @notdoneityet
                Posted by Vic on 13/09/2019 15:36:14:
                I think I would take the simple option and use the other chuck. smiley
                I have one chuck always holding a centre drill. Quicker to change the chuck than changing from centre drill to a larger drill bit. I don’t lose the centre drill as easily that way, too.smiley
                #428900
                Anthony Knights
                  @anthonyknights16741
                  I made a spring centre using a MT2 blank. Just swop with the chuck when it needs to be used.spring centre.jpg
                  #428932
                  Trevor Drabble 1
                    @trevordrabble1
                    Vic , Are the ones from Arceuro not suitable ?
                    Trevor.
                    Edited By Trevor Drabble on 14/09/2019 11:07:22
                    #428939
                    not done it yet
                      @notdoneityet
                      Well done, Anthony. Simple and no need for a computer to design.smiley KISS principle definitely in operation there.
                      Questions: Did you actually harden that point? If so, why?
                      added: good for the lathe. Not quite so fast, to change over, on the mill.
                      Edited By not done it yet on 14/09/2019 12:10:47
                      #429080
                      Anthony Knights
                        dscf3274.jpgHi NDIY. The point isn't hardened. The oxide colours are a result of silver soldering the 10mm collar on the other end of the shaft.
                        edited to add photo
                        Edited By Anthony Knights on 15/09/2019 13:45:23
                        #430300
                        Vic
                          @vic
                          Posted by Trevor Drabble on 14/09/2019 11:06:25:
                          Trevor.
                          Not sure. I did buy a commercial one once but it was so wobbly I had to ream the hole and make new innards to make it usable.
                          I’ve now made a 10mm shaft version so all sorted.
                          I have in the past resorted to just using a pointed length of steel in the chuck but not being spring loaded is less convenient.
                          As for turning down a 1/2” model, I doubt there’s enough material on the ones I have. One in particular has a 10mm grub screw in the back.
                          #430337
                          not done it yet
                            @notdoneityet
                            Posted by not done it yet on 14/09/2019 02:56:13:
                            Go on, tell us why you don’t use the other chuck. Seemed, to me, to be the obvious solution – but there must be a sensible reason why you don’t use the one (of the two) that is large enough?
                            #430339
                            Vic
                              @vic
                              NDIY, the Z space on my mill can be limiting so it sometimes helps to use the smallest Chuck I have. There are other ways round it like using a collet direct in the spindle but for most jobs it’s more convenient to keep the chuck in the quill.
                              #430364
                              not done it yet
                                @notdoneityet
                                Thanks for the reason. It just seemed the sensible way to go, because of the info provided in your thread opening post.
                                How much longer is this other small chuck? Is there scope to slightly shorten the spring-loaded tip of just one of your three tapping guides?
                                I was likely thinking ‘lathe’ and not ‘mill’ as well. Again, the comprehensive detail only emerges much later.smiley
                                #430431
                                Vic
                                  @vic
                                  I’ve just checked and there is a 30mm difference between my Albrecht 16mm and Rohm 10mm. It doesn’t sound much but can make the difference with some jobs.
