Cuttlefish shell (you know – like budgies gave in their cages) was used for making small single sided castings – press the original pattern into the soft side and pour your solder into the depression that is left.
Alternately try some lost wax casting by covering or investing a wax pattern in plaster inside a short length of copper tube with a funnel like entrance at the top. Heat until the wax has melted away and then melt some solder in the funnel. Clap a metal lid on with a circle of wetted cloth in it (I used to use the lid of a pipe tobacco tin) and the steam will force the metal into the mould. Break out your finished casting. You will need more heat for this though.
This method was used by dental technicians years ago and I attended a demonstration at the Nottingham SMEE in the seventies before trying it out myself with what was then called students metal, however I suspect that you will need absolution from H&S to do it today!
