simple tongs
simple tongs
Home › Forums › Workshop Tools and Tooling › simple tongs
  • This topic has 12 replies, 6 voices, and was last updated 13 July 2020 at 23:16 by celso ari schlichting.
  • #484969
      @celsoarischlichting85092
      how i make this simple tongs:
      Greetings from Brazil
      Celso Ari
      #19858
        #485010
        IanT
          @iant
          I liked the small welded fabrication aspect Celso, simple MMA and it looked vey good after grinding. The oil quench was a bit hairy – definitely an outside job.
          A well made and useful Blacksmiths tool though. Well done and thank you for sharing!
          IanT
          #485081
          Grizzly bear
            @grizzlybear
            Very good, you made it look easy. But many operations.
            I too liked the pivot.
            Do you read the English OK, or do you translate?
            Regards, Bear..
            #485102
              Posted by IanT on 11/07/2020 10:16:10:
              IanT
              Thanks Ian…Regards from Brazil
              #485103
                Posted by Grizzly bear on 11/07/2020 18:50:34:
                Regards, Bear..
                Dear friend Bear, I understand a little English, I get a little confused when people
                use slang or very technical or specific words, except that I can communicate
                reasonably well
                #485111
                DMB
                  @dmb
                  Celso Ari,
                  If you do not understand a word, try the translator and if its still a bit confusing, private message the person who posted it. Never be afraid to ask, one or more of us will try to explain things. Not helpful that there is different slang used in different areas of UK and some things have a different name depending on which part of the country. An English Lake is an Irish Lough or a Scottish Loch. There are many more examples.
                  DMB
                    @dmb
                    Celso Ari,
                    Just watched your youtube on making tongs. Thanks for sharing. I like your design of the joint, might make a set of tongs using your design.
                    Bill Dawes
                      @billdawes
                      Well done, greetings from Somerset in the UK. Something I have been thinking about for a while so this has given me some inspiration, It is about time i used my welder I have buried in the back of the garage, never used it enough to get past the stick welding itself to the job! Thank you for sharing, interesting to see how many different parts of the world we get posts from on this forum.
                      Best regards
                      Bill D.
                      #485244
                        The best translator I have found is DeepL
                        O melhor tradutor que encontrei é DeepL
                        https://www.deepl.com
                        Edited By Michael Gilligan on 12/07/2020 18:31:21
                        #485518
                          Posted by DMB on 11/07/2020 22:22:00:
                          Celso Ari,
                          Thanks John, I'm glad you liked it … a big hug from Brazil
                          #485520
                            Posted by Bill Dawes on 12/07/2020 13:21:11:
                            Best regards
                            Bill D.
                            Bill, a welding job always helps in completing a project and is one of the things that I use a lot in the workshop
                            Cheers
                            Celso Ari
                            #485521
                              Posted by Michael Gilligan on 12/07/2020 18:30:06:
                              Michael, i will definitely use it soon, thanks for sharing
