Silver Steel
Silver Steel
Home › Forums › Materials › Silver Steel
  • #30195
    Vic
      @vic
      #578718
      Vic
        @vic
        Anyone tried forging it? I’m guessing it’s going to be tougher to work than mild steel. Also, is it Basically the same as O1?
        #578814
        Vic
          @vic
          Update. Actually I’ve been thinking about this some more and I can machine what I have in mind rather than using than resorting to heating it up and using my anvil! laugh
          #578857
          MikeK
            @mikek40713
            I thought you gents called "silver steel" what us yanks call "drill rod"? Which would be O1 and W1, for me. I forged it once. I only needed a slight dogleg in a piece and it was tough.
            #578866
            Neil Lickfold
              @neillickfold44316
              Silver steel forges just fine, as long as it is still above red hot when struck by the hammer. After shaping, I have then heated the part in an oven an and then cooled slowly in the oven. After this have finished the shape and then heat treated it. Silver steel I have always called Stubbs W1, the water quench material. The oil Quench I always call it O1 and Not Silver steel.
              #578892
              Philip Rowe
                @philiprowe13116
                Forging a piece of silver steel was the very first exercise I did as an apprentice nearly sixty years ago. Under the tutoring of the apprentice instructor four of us had to produce a fairly basic screwdriver from 1/4" dia silver steel, the end being flared out to maybe 3/8" wide. The other end was forged into a tapered square section which was later burnt into a file handle, lots of smoke and smells! The blade was then hardened and tempered, polished and I'm sorry to say never ever used as a screwdriver but it did teach me quite a lot about silver steel. Phil
              Home › Forums › Materials › Topics
