Silver soldering contradiction
Home › Forums › General Questions › Silver soldering contradiction
Viewing 25 posts - 1 through 25 (of 49 total)
  • #349906
    Eric Cox
      @ericcox50497
      There appears to be a contradiction of opinions regarding silver soldering in the latest addition of ME no.4584.
      On p585 it states there must be a gap of 0.1mm for capillary action to take place and on p594 it states that all joints are pulled up tight with no obvious gaps even to the extent of riveting parts together
      Gap or no gap ?
      #25936
      Eric Cox
        @ericcox50497
        #349909
          Really comes down to "what size gap"
          It is usual to just give boiler rivits a light tap, enough so that they hold the plates in place and give the "tightish" fit mentioned but not to fully hammer them down resulting in a tight joint.
          If you do need to hole two parts together during soldering then you can also either place solder foil in the joint or add a few punch marks to the surface which just holds the plates a fraction apart so the solder can flow. With sheetwork as found in boilers you will also get some expansion as the metal is heated which tends to open up the joint as well so what may have been together when cold will have a suitable gap once hot.
          The gaps Terrance is talking about are large ones that will need a lot of solder to bridge and that is if it will stay in the gap more than likely it will just run to another part of the job or onto the hearth
          Edited By JasonB on 12/04/2018 10:04:24
          #349910
            I suppose it depends on the second author's definition of "obvious"
            A finite, but small, gap is required … with 0.1mm being a reasonable maximum [?]
            Jason beat me to it.
            Edited By Michael Gilligan on 12/04/2018 10:04:12
            #349919
            Bob Stevenson
              @bobstevenson13909
              interesting topic……..
              In practice i have found that the smaller the 'gap' the better….it's normal when making clock parts to clamp the parts tightly together and I can't remember the last time, or any time come to that, when the tightness of the joint prevented the solder from flooding the joint. I normally use a couple of old engineers clamps, amongst other stuff, and use quite a lot of pressure but the solder still runs and I like the joints to be as inconspicuous as possible so usually put some effort into getting a very close fit before soldering. When I solder spring barrels together I use a warding file first while holding the tube closed against the file until no light coes thru the joint…then the soldered joint is such a fine silver line that it can be easily polished out to invisibility.
              #349931
              nigel jones 5
                @nigeljones5
                Take it from me, a gap is the very last thing you want when silver soldering, at least in terms of what the average person regards as a gap. I soldered a boiler end plate which had a couple of thou gap yesterday – absolute nightmare, I should have just remade the part. In copper The best result is obtained whjen the pieced are a tight fit, yes, I said tight fit! I completely agree with Bob. I have read many times referance to leaving a gap and have to conclude that anyone who tells you to leave a gap has absolutely no experience whatsoever of silver soldering.The Australian code body did some interesting research and testing of copper boiler end plate joints a while back, I cant post it as I no longer have it but if anyone else does it blows apart a few of the myths regarding phlanging and solder penetration.
                #349934
                Nick Cliffe
                  @nickcliffe94153
                  I've been trying to braze brass handles to brass plates using silver solder and it was a nightmare. I used 55% silver solder in thin wire format and the powdered flux. Then I spread the flux throughout the joint heated the brass up until glowing red and then applied the solder.
                  But all that happened was that it beaded and fell off – nothing crept into the joint. The heat caused the copper in the brass to leech out to the surface so it looked a real mess.
                  In the end I used JB Weld!!! What did I do wrong?
                  Best wishes,
                  Nick
                  #349935
                  Hopper
                    @hopper
                    Seems to be some similar mythology about leaving a gap for Loctite too, despite their own literature recommending otherwise.
                    In both cases, it seems people tend to forget the surface imperfections of even a quite smooth looking metal surface provide ideal "channels" for liquid to penetrate, be it molten solder or Loctite etc.
                    #349937
                    shaun meakin
                      @shaunmeakin78815
                      The strength of a silver solder joint comes from the ability of the alloy to flow into a gap by capillary flow, No gap = no joint, simples!
                      It is true that the narrower the gap the better the capillary flow, but again there must be a gap.
                      [email protected]
                      #349939
                      shaun meakin
                        @shaunmeakin78815
                        I should have also said the gap is at brazing temperature. Fizzy were you brazing two pieces with different expansion properties? It might be the joint opened up or closed tight on heating thereby causing problems. Heat pattern is also important. The alloy will always flow to the hottest point so ensure once at temperature the flame is applied where you want the alloy to go, not where you are applying it to the joint.
                        #349941
                          I suppose most of us do not section our joints after they are made, hard to tell if the solder has simply run all around the edge of the two parts or if it has flowed right into it without cutting in half and looking.
                          I probably get to see my joints more with teh fabrication work I do as they are often machined after soldering which can cut across a joint, not something you tend to do on a boiler.
                          #349944
                          norman royds 2
                            @normanroyds2
                            on understanding gap when silver soldering is when doing boiler tubes I dill then ream till i just get movement the tube moves no visible gap but I get perfect joint the fact is no visible gap but movement because there is clearance plus the flux in all joint must give clearance regards norm
                            #349947
                            IanT
                              @iant
                              There has to be some "gap" – albeit only a very small one.
                              I am lucky enough to have copies of Kozo Hiraoka's Shay/Climax/Heisler books and since reading them, I've used his recommendations on making good silver soldered joints and fabrications. He goes into the requirements for a good joint in great detail but it can be summarised under the following headings:
                              1) Use a suitable silver solder and flux
                              2) Select an appropriate heat source (i.e. torch)
                              3) Clean the joint surface(s) well
                              4) Provide appropriate clearance (by machining, by punching or by filing)
                              5) Fit the parts together securely (but do NOT use clamps!)
                              6) Silver solder only a few joints at a time (and clean everything between 'solders' )
                              7) Always flux before assembly
                              8) Set up an 'assembly' – such that gravity will assist the capillary action (rather than resist it)
                              9) Provide the part(s) with support where necessary
                              10) Apply heat from the back wherever possible
                              11) Apply the heat to the heavier part
                              12) Help the flow of solder with a 'scratch' rod
                              This is detailed in Kozo's 'Shay' book but referenced in the others too – but is the best all round description of how to make small soldered fabrications that I think I've seen.
                              As mentioned, he always makes a slight "gap" between the parts to be silver soldered. I've found his idea of using a centre punch to make a few 'dimples' on one part ( very small 'stand-offs' ) – to hold the two surfaces slightly apart (thereby enabling capillary action) very useful.
                              BTW – The Kozo books are still available from Village Press in the US (not that cheap I'm afraid given $/£ exchange rates but still much less than some eBay/Amazon sources would suggest). They are beautifully written and illustrated and contain many novel and useful ideas and techniques for any ME. They would certainly be on a short list of my favourite modelling/engineering books.
                              IanT
                              Edited By IanT on 12/04/2018 13:27:56
                              #349948
                              HOWARDT
                                @howardt
                                If you have ever soldered standard 15mm (or 22) pipe fittings then that is an ideal fit. Pipe fitting manufacturers can't supply fittings that won't solder 100%. In other words a nice tight sliding fit.
                                #349949
                                Bazyle
                                  @bazyle
                                  It is worth the enormous cost of two half inch square pieces of metal and 1cm of solder wire to experiment to see just how thin and 'flowy' solder becomes when melted. Point to note is that it is not like the old plumbers solder that was specifically designed not to flow too easily so it could be used for gap filling ropey bits of pipework.
                                  #349951
                                    I think we should also take into account the two jobs being discussed in Eric's opening post and throughout this thread.
                                    The article which mentions the need for a gap refers to a fabricated feed pump body but the one that says there should be no "obvious gaps" is reffering to soldering a boiler.
                                    As I said earlier joints will open up in some instances particularly where you have a flat plate in a round tube, I have noticed this when soldering spokes into rims where a very noticable gap can appear from what was a push fit when cold. So in this instance there is no real need to add a gap.
                                    However when soldering two blocks of metal together when fabricating a part and needing to hold them in position during soldering be that with screws, claps, etc you can risk closing the joint too much and not getting the solder to penitrate, you may have a nice fillet all the way around the outside but the mating faces could well be dry.
                                    This is why all the different solders state the required gap at brazing temperature not when its in your hands looking for a gap, see item 1, one would hope Jm know what they are talking aboutsmile p
                                    Edited By JasonB on 12/04/2018 13:55:12
                                    #349953
                                      Posted by shaun meakin on 12/04/2018 11:58:10:
                                      [email protected]
                                      Predictably enough … Shaun seems to have summarised perfectly ^^^
                                      chris stephens
                                        @chrisstephens63393
                                        Gap or no gap that is the question. Answer is staring you in the face, if you flux the joint, as you most assuredly must do, there will be enough of gap for the solder to flow into by capillary action. So for the naysayers, if you flux properly you do have a gap. Discuss.
                                        chriStephens
                                        #349957
                                        J Hancock
                                          @jhancock95746
                                          We really need a metallurgist to explain what really happens when you 'solder stuff' together.
                                          Under all the smoke and flames I think you would find an awful lot of 'alloy' chemistry going on.
                                          If it doesn't happen, you might as well use Araldite to stick it together.
                                          #349958
                                            Posted by J Hancock on 12/04/2018 14:16:23:
                                            Try this: **LINK**
                                            https://www.asminternational.org/documents/10192/1849770/05338G_Sample_eBook.pdf/8dd737af-b574-45b8-ab4f-ea2e5843f8e7
                                            [quote]
                                            The bond between solder and base metal is more than adhesion or mechanical attachment, although these do contribute to bond strength. Rather, the essential feature of a soldered joint is that a metallurgical bond is produced at the filler-metal/base-metal interface. The solder reacts with a small amount of the base metal and wets the metal by forming intermetallic compounds. Upon solidification, the joint is held together by the same attraction between adjacent atoms that holds a piece of solid metal together. The ease of wetting (discussed later) is related to the ease with which this solvent action occurs. The presence of the base-metal/ filler-metal reaction is one factor in the wetting action of the solder. Other factors include surface cleanliness and solder surface tension (that is, capillary flow).
                                            [/quote] [copied & pasted from the web page, then tidied-up]
                                            Edited By Michael Gilligan on 12/04/2018 14:31:25
                                            #349963
                                            not done it yet
                                              @notdoneityet
                                              You don’t really need to know the reactions at the atomic level. All you need to know is that if there is no possible gap for the solder to flow across the joint, there will only be a soldered line at the external or internal contact point. This is simply not good enough – the joint needs maximum surface area to be properly effective.
                                              It would be like stick electric welding a butt joint without any weld depth – pretty useless under high load, and further, access to the other side of the joint may mean a single line of solder along one corner rather than both sides and the butt end being attached.
                                              I think metal is generally rather stronger than plastic (epoxy resiins) and most certainly has a far higher temperature range of application!
                                              #349967
                                              Former Member
                                                @formermember19781
                                                #349968
                                                Rod Renshaw
                                                  @rodrenshaw28584
                                                  Hi all
                                                  Can I ask what readers think about the need for cleaning the joint surfaces before silver soldering which has been mentioned in passing several times in this thread?
                                                  The writings of the late Tubal Cain emphasised the need for absolute cleanliness, and he quoted the relevant British Standard in his own support.
                                                  Conversely, the chap from Cup Alloys who delivers the excellent lectures at ME shows, and who is clearly very experienced, seems to feel that the flux will clean the metal at brazing temperatures so cleaning is not important.
                                                  Regards Rod
                                                  #349970
                                                  Jeff Dayman
                                                    @jeffdayman43397
                                                    I've always tried for best cleanliness, enough good quality flux, and adequate heat when silver soldering, and have had consistently good results for many years. I typically leave a two or three thou gap between parts. I too read about Kozo Hiraoka's centre punch mark gap generation method many years ago and use it often.
                                                    Just my opinion and $0.02 worth.
                                                    #349975
                                                    KWIL
                                                      @kwil
                                                      Remind me not to buy a boiler from Fizzy, cavalier attitude to say the least.
                                                      Edited By KWIL on 12/04/2018 16:59:16
