Siemens Micromaster 420 VFD queries.
Home › Forums › General Questions › Siemens Micromaster 420 VFD queries.
  • #357018
    Andrew Tinsley
      @andrewtinsley63637
      Hello,
      Just starting to sort out a Micromaster VFD with the basic operating panel (BOP).
      I assume that I can construct a remote pendant control for stop/start, alter frequency and jog, by directly connecting the pendant to the VFD? or are you restricted to doing this via the BOP?
      I have yet to wade through all the operating instructions which I am sure will reveal what can and can't be done. However I usually get a headache when trying to sort out the instructions. There is so much stuff that I will never need and what I want is usually the last place I look!
      Thanks,
      Andrew.
      #26017
      Andrew Tinsley
        @andrewtinsley63637
        #357020
        John Rudd
          @johnrudd16576
          Yes, you can control the inverter via a diy pendant. Use the digital inputs configured as required, connect a 5k pot to terminals 1,2&3 and tell the inverter what you want to do…..
          #357029
          Andrew Tinsley
            @andrewtinsley63637
            Thank you John,
            Just a quick query, Can I instruct the VFD via the basic operating panel or do I need the advanced AOP panel?
            Andrew.
            #357039
            John Rudd
              @johnrudd16576
              My intepretation of the manual is that you can……..of course , I stand to be corrected…
              #357042
              Andrew Tinsley
                @andrewtinsley63637
                Thank you John,
                I shall now take some Paracetamol and see how I get on!
                Andrew.
                #357044
                John Rudd
                  @johnrudd16576
                  Programming can be fairly straightforward, if you take your time and have the motor/inverter and manual in front of you….
                  #357045
                  Andrew Tinsley
                    @andrewtinsley63637
                    Hello John,
                    It isn't the programming per se that I find complicated. It is trying to find the appropriate bits which one actually needs. I guess that is about 5% of the actual capabilities of the VFD, are the ones I want and I tend to get lost in the other 95%!
                    Really it serves me right, I should stick to one make of VFD and then setting up the second or third one is easy. I tend to buy VFDs that are good value and that means I never get the same type twice.
                    Thanks again,
                    Andrew.
                    #357046
                    Nick Hulme
                      @nickhulme30114
                      Andrew,
                      The Siemens documentation is very good, you shouldn't have any problems,
                      – Nick
