PTFE or not
PTFE or not
Home › Forums › General Questions › PTFE or not
Viewing 25 posts - 1 through 25 (of 30 total)
  • #22837
    Springbok
      @springbok
      Help Please
      #130054
      Springbok
        @springbok
        Hi everyone I landed on about 7 kilos of plastic, rod, bar and block.
        Mainly in white but there is black, blue.
        Now I wish to give some if this away to variose club members but want to know what I am giving them, On one of the white bars is stamped BS EN 15860 but web site gives no info on if it is Nylon, Acetal, PTFE. Suspect it is Acetal as it came out of an engineering workshop. But would like to be sure.
        I stuck a small block on the mill and it machines nicely.
        Thanks
        Bob.
        #130055
        Russell Eberhardt
          @russelleberhardt48058
          There's a useful guide here
          Russell.
          #130058
          Brian Jopling
            @brianjopling20760
            I would be very wary of inhaling burnt of burning plastic. Many are very toxic
            Jopo
            #130059
            Brian Jopling
              @brianjopling20760
              PTFE, very good for bearings but expensive, has a greasy feel is almost (always?) a off dull white shiny finish and is heavy compared to nylon, acetal, pvc.Bit heavier than Delrin but easy to confuse. PTFE machines very well and takes a good finish with a hss flat or slightly negative rake tool with a stoned radius. Back off drills or they will pull in (same as brass)
              Do not inhale dust or fumes – wet polish and grind onlysmiley
              Jopo
              #130062
              MadMike
                @madmike
                Beware of names when dealing with plastics. SAfter all Delrin, amongst others, is really only a brand name for Acetal. The same applies to many nylon based products. Colour is usually an irrelevance as they can be and often are many colours.
                #130064
                jason udall
                  @jasonudall57142
                  Mike .I think you might find though Delrin is a trade name that it has different properties to acetal.
                  And colours can have an effect on material behaviour ( the dyes do have some impact)..as to nylon…many many flavours…..
                  #130065
                  David Jupp
                    @davidjupp51506
                    Delrin is the DuPont brand name for acetal homopolymer resins. There is a familiy of different grades of Delrin (as is the case with many plastics). You might find some copolymer products described as acetal. Different manufacturers may use slightly different processes to produce chemically similar products, and there may well be subtle differences between products from different processes.
                    Most polymers can get very complicated if you start to look into the fine detail, and that's before people start modifying their behaviour with any additions.
                    #130066
                    David Jupp
                      @davidjupp51506
                      BTW – don't be tempted to try burning tests on anything that might be a fluorinated polymer (including PTFE). People have died (Hydrofluoric Acid is VERY nasty and can be formed when these are burned).
                      #130067
                      jason udall
                        @jasonudall57142
                        Re burning…this includes nitrile ruber seals and o rings..
                        And I have seen ptfe described as precursor of sarin..
                        So dispose of with care
                        #130068
                        jason udall
                          @jasonudall57142
                          ..ptfe..don’t we put that on frying pans?
                          Makes yer think
                          #130074
                          Trevorh
                            @trevorh
                            if the products are nylon then the colour refers to the hardness and machine-ability
                            white being the softest then Blue and finally black, there are If I remember 2 more colours in the set
                            all except white are good bearing materials with low co-efficient of slip and excellent machining qualities – used in the print/packaging industry all the time
                            cheers
                            #130089
                              Posted by jason udall on 18/09/2013 17:05:57:
                              ..ptfe..don't we put that on frying pans?
                              Makes yer think
                              See here, for some thinking
                              and here, for a typical MSDS
                              If I recall correctly; there were a couple of cases in the late sixties, or early seventies, where someone accidentally contaminated a roll-up cigarette with a strand of PTFE swarf. This is a very good way of ingesting the products of combustion! … We were certainly made very aware of that risk when I worked at Kodak.
                              ChrisH
                                @chrish
                                When I worked in the food industry conveyor chains used to run on green 'plastic' (of some description) strips which were of low friction, even less friction when conveyor lube (a sort of soapy water) was sprayed on.
                                Never knew what the stuff was called, was always referred to as "that greeen stuff". Anyone know what "that green stuff" was called?
                                Chris
                                Edited By ChrisH on 18/09/2013 23:21:40
                                #130097
                                David Jupp
                                  @davidjupp51506
                                  Colour is usually of minor significance with regard to either properties or identification of polymer type – most polymers can be coloured to any of a wide variety. Some pigments will alter other properties to a degree.
                                  Some companies however may always purchase particular polymers in specific colours to aid internal identification (or to make any bits that fall off show up in the food).
                                  Friction properties can often be modified by incorporation of various additives. The specific behaviour you witness may not be a natural property of the polymer – this can make identification even trickier.
                                  #130098
                                    Posted by ChrisH on 18/09/2013 23:21:07:
                                    Chris
                                    Possibly UHDPE
                                    Jerry Wray
                                      @jerrywray14030
                                      I note with interest Michael's post above which links you US sources.
                                      If you don't have an interest in safety of chemicals don't bother reading ths, it's tedious but as this is my day job I feel I need to contribute to the sum of human misery by a short teach-in.
                                      Regrettable these give a somewhat restricted view of the toxicology of PTFE.(Cas RN:9002-84-0). Congess has recently decided to implement the GHS (Globally Harmonised System of Classification and Labelling) to address shortcomings in the present system,which willin the future require any MSDS to actually provide information rather than generalities. US MSDSs are not valid in the EU.
                                      The relevant EU document is known by the acronym SDS (Safety Data Sheet). These contain specific information conforming to regulation and based on validated testing regimes.The ECHA (European Chemicals Agency) based in Helsinki is managing the REACH system and publishes various pieces of data. If you go to their website **LINK**
                                      and key into the search box the CAS number 9002-84-0 (not forgetting to tick the agreement box you will find the EU Harmonised classification which indicates in coded form the various hazards of this chemical.
                                      Further searches within the ECHA website will reveal the basis of this information; which is backed by peer review. Details of how to carry out such searches are beyond the scope of this post.
                                      I warned above that this was going to be tedious.
                                      In the end the ECHA classification confirms that PTFE is as bad, possibly worse than Michael has indicated.
                                      Happy reading.
                                      Jerry
                                      #130107
                                        Jerry,
                                        Thanks for the info.
                                        Ian S C
                                          @iansc
                                          I hear that PTFE is to be withdrawn from use on the likes of fry pans in the next year or so. Ian S C
                                          #130134
                                          Russell Eberhardt
                                            Posted by Brian Jopling on 18/09/2013 12:26:49:
                                            Jopo
                                            Quite, however that data sheet said, "cautiously smell the fumes". The nose is very sensitive and can detects smells at very low concentrations, well below dangerous levels. However, if you are not sure of what you are doing it's better safe than sorry.
                                            Russell.
                                            #130147
                                            Springbok
                                              @springbok
                                              Wow
                                              Thank you all for your replys even had a member want me to send samples to his lab
                                              I do not smoke have not done for 50 years,
                                              Once again thanks
                                              Bob
                                              #130159
                                              Chris123
                                                @chris123
                                                Delrin is a trade name of DuPont. I used it years ago, it can give off some nasty fumes that can cause you to go dizzy and lose balance. Don't ask me how I know!
                                                #130181
                                                Jerry Wray
                                                  @jerrywray14030
                                                  Ian S C
                                                  May I ask what your references are for the withdrawal of the use of PTFE on frypans?
                                                  Jerry
                                                  #130183
                                                  Sub Mandrel
                                                    @submandrel
                                                    The Daily Mail? Type PTFE frying pan and google automatically offers "teflon frying pan dangers" with this as one of the results.
                                                    "NON- stick frying pans release chemicals linked to liver disease and cancer into … most dangerous drug of our time' and should come with smoking-style health "
                                                    But they say the Mail divides everything in the universe into those that cause cancer and those that cure it (some things are in both categories).
                                                    Chris123
                                                      @chris123
