Preventing scaling
Preventing scaling
Home › Forums › Workshop Techniques › Preventing scaling
Viewing 25 posts - 1 through 25 (of 37 total)
  • #15724
    Brian Wood
      @brianwood45127
      Heat treatment of gear cutters
      #161221
      Brian Wood
        @brianwood45127
        Some advice please.
        I have made two multi tooth gear cutters in boron steel of about 60 mm diameter, 1 inch bore and 6 mm in section thickness; the next stage is to harden the cutting teeth.
        I want to restict the risk of scaling in the bore and location faces next to the bore and as I don't have suitable grinding facilities to finish those they are machined to size.
        Can anyone recommend an effective coating that will do this for me please?
        Many thanks
        #161223
        Michael Cox 1
          @michaelcox1
          Soft soap smeared on the part before heating limits the scaling on steel quite well. In the past you could by soft soap from Boots but I do not think they stock it any more. It can be bought on ebay. I have experimented with ordinary soap shaved into small pieces. It is best to heat the part gently and then dip it in the soap that will then melt and cover the surface. Then you can heat the part to red heat and quench with little scale forming.
          #161224
            When I have used Tipex correction fluid to stop silver solder spreading there is no sign of scale under the tipex, may be worth having a try on some scrap as the hardening temperatures will be a bit higher. Use the solvent based one.
            J
            #161228
            speelwerk
              @speelwerk
              I use "Condursal Z0095" which works up to 850C, for higher tempertures they recommend "Condursal Z1100" with which I have no experience. You cannot use it in a flame since you have to be precise with your temperature. Niko.
              #161232
              Brian Wood
                @brianwood45127
                Gentlemen,
                Thank you for your suggestions
                Michael. I'll see what the guvner can provide in the way of soaps to try out.
                Jason. I tried your suggestion as I have Tippex in the house. Testing was done on a small sample of the steel used for the cutters, painted on one side and open on the other. At red heat I could see scale forming on the unprotected side and after quenching the painted side was a lot cleaner, not spotless it must be said. Out of interest I took a sample up to gas welding temperatures, here the Tippex failed as you would expect in a severe test like that.
                Niko. Duffy Condursal is probably excellent but buying and shipping from Illinois for a small job like mine is completely unrealitic; if the job is a disaster it is easier to make new parts and try again. If I was doing it every day that might be a different matter.
                On balance I might try a combination approach with soap and Tippex, the Tippex is visible which helps a lot in monitoring the effects
                Thank you all again
                Brian.
                #161234
                speelwerk
                  @speelwerk
                  Brian, it is a bit far fetched to get it from Illinois, I bougth it locally here in NL, as far as I know it is a German product. Niko.
                  #161244
                  Brian Wood
                    @brianwood45127
                    Hello Niko,
                    I looked the product up and was taken straight to the Duffy page in the USA. I would need to look for it from a UK stockist in Yorkshire, next move if the other methods fail me.
                    Thank you again for you interest
                    #161252
                      I've heard powdered french chalk, mixed to a thick paste with meths, suggested specifically as it helps stop the steel losing carbon.
                      Brian Wood
                        @brianwood45127
                        Hello Neil,
                        I have seen whiting (what ever that is) mixed with meths as a recommendation. Checking out French chalk I find it is actually ground talc and that of course is talcum powder, so I will experiment with that as well. At least the perfume will inprove the smell of the job! Another experiment would be to mix plaster powder (gypsum—calcium sulphate) with meths.
                        Just for reference, my wife laughed when I asked about soft soap—–unobtainable she tells me. It is based on potassium stearate rather than the much cheaper sodium stearate, the basis of ordinary soap, and that difference is where the 'soft' bit comes from. Today those more gentle soaps have all been replaced by pump action oil based creations, probably completely unsuitable for this purpose.
                        #161275
                          I think I meant ordinary chalk (calcium carbonate) non-carbonates won't help prevent de-carburisation.
                          Keith Long
                            @keithlong89920
                            In an old copy of "Fowlers Mechanics & Machinists Pocket Book" it suggests using fireclay to blank off areas that are to remain soft when case hardening. The provisos listed are that care should be taken to ensure good adhesion and that the clay should be quite dry before the item is placed in the case hardening box. Now I know you're not case hardening but Pyruma fire cement is available pretty cheaply and might be worth a go on some scrap material to see if it works. It isn't going to be worried by the temperature and should chip away after fairly easily.
                            In the next paragraph the possibility is brought up of electroplating copper onto the parts not to be hardened, that might also work to avoid scaling, or possibly easier what about fastening some copper shields in place over the location faces with a bolt through the bore which should be protected at the same time.
                            #161287
                            Brian Wood
                              @brianwood45127
                              Thank you Keith—–more interesting possibilies. Pyruma is easy to get hold of and well worth trying.
                              I could use it to seal copper shields, that combination will keep oxygen away and thus the scaling.
                              #161298
                              jaCK Hobson
                                @jackhobson50760
                                Heating and quenching in heat-treating salts is a way of minimising scale. On a small scale you could try heating in Lo Salt from the supermarket (try on scrap part first). You will need a decent heat source to get the salts hot enough. Be careful.
                                Low temp (quenching) salts are not so easy to get. Hot blueing salts may do the job. Maybe a normal oil or water quench won't leave too much scale anyway.
                                In the past I have been advised to put the part in a small container with the end packed with clay. Heat the lot up in a suitable furnace/forge and put the container clay first into the quenchant. The clay should fall out the bottom, and the part with it. This is probably more efficient at minimising decarb rather than scale and for smaller parts that would fit in a tube. So probably not right for you.
                                I've never tried any of those. I have some fancy anti-scale mixture imported from US which is better than nothing but not perfect for large parts.
                                #161304
                                speelwerk
                                  @speelwerk
                                  Copper will turn very soft at high temperture, it would be better to shield with the same material as the piece is made of. Niko.
                                  #161320
                                  JohnF
                                    @johnf59703
                                    Brian, I use Zebo black lead grate polish for stopping scaling on the inside of gun barrels for a particular process but it is "supported" with steel plugs so not sure how it would perform just painted on but maybe you can make a plug with some clearance and a washer either side well lubricated with Zebo.
                                    It certainly stops any scaling for me. Just google Zebo black lead.
                                    Brian Wood
                                      @brianwood45127
                                      Hello Niko,
                                      More good advice, thank you.
                                      The cutters will be at temperature for about 1/4 hour using the usual mantra of 1 hour per inch of thickness, that gives plenty of time for copper shields to sag away.
                                      #161325
                                      Brian Wood
                                        @brianwood45127
                                        Hello John,
                                        I've used Black lead as grate polish in the past, just never considered it for this application. The last time I used it the formulation had given it an almost silvery appearance, certainly not black as it had been. I think in the end I used to add graphite to shoe polish and use that instead.
                                        In your case scaling would be very bad news and the sealed plugs are perhaps doing much of the work, but there will be residual oxygen in the barrels before you seal them.
                                        I will mull over all the contributions and choose a path, at the moment shields and plugs sealed with Pyruma is my favourite
                                        Jack Hobson
                                        I don't have the facilities for heat treatment salts but I do have a small muffle oven, so it will have to be the more traditional methods of heating and soaking at temperature followed by water quenching. My experiments on small samples of this boron steel so far leave them hard enough after quenching, but I have yet to try the effects of stress relief. Local industrial advice was to use a domestic oven at 180 Centigrade
                                        #161336
                                        John Haine
                                          @johnhaine32865
                                          Borax? Doesn't flux stop surfaces oxidising?
                                          #161352
                                          John Ockleshaw 1
                                            @johnockleshaw1
                                            Hello Brian,
                                            I do not know which of the boron steels you have used, but if it has any of the nitriding agents in it you may consider nitriding them. You can do this at home if you do not mind going to a fair bit of trouble or otherwise send them out to commercial heat treaters
                                            #161358
                                            Vic
                                              @vic
                                              Not sure if it's suitable for your project but I understand parts can be wrapped in stainless steel foil for heat treating. Don't know where you can buy it though.
                                              #161366
                                              Brian Wood
                                                @brianwood45127
                                                Hello John Ockleshaw and Vic,
                                                I have spoken to a local heat treatnent business, they even know the boron steel I am using, but they don't have, or don't bother with small scale facilities for one and two off's as these will be. The neat way would be to induction harden the rim with the teeth, but that is not available with these people.
                                                I suspect I would have to travel to Gateshead of even further afield to get professional help of that kind and for the few gears these are to make the effort and cost of it all would be self defeating.
                                                Vic. I don't know where stainless steel foil can be acquired either, for this job I will make compatible shields and clamp them in position, using Black Lead, powders in meths or Pyruma as sealants depending on the results of trials on test sections.
                                                Thank you though for the interest and suggestions
                                                Edited By Brian Wood on 21/08/2014 09:41:43
                                                #161375
                                                Vic
                                                  @vic
                                                  #161415
                                                    I wondered if you could make a muffle tube with blanked off ends an inlet and a small hole, then use a gentle flow of welding gas (e.g. CO2) to heat treat in a totally safe atmosphere?
                                                    Brian Wood
                                                      @brianwood45127
                                                      Vic,
                                                      Thank you for the information useful to know as well
                                                      Neil,
                                                      An interesting thought; I only have CO2 available as soda stream cylinders and without a regulator and my welding is only Oxy Acetylene, neither of which would be wise as a blanket gas!!
                                                      I do have a small muffle oven and the concept might be good for a run of work, but for just two cutters the other alternatives I am considering are simple and probably effective enough
                                                    Home › Forums › Workshop Techniques › Topics
