press fit sizes
press fit sizes
Home Forums General Questions press fit sizes
  • #380340
    martin perman 1
      @martinperman1
      Gentlemen,
      I am going to make four 2.5" rollers for a friend with .5" axles using silver steel what drill size could I use to get a light press fit or would I need to ream the hole .5"
      Martin P
      #26292
      martin perman 1
        @martinperman1
        #380341
        vintage engineer
          @vintageengineer
          As a rough guide you need the hole .001" per inch undersize. So you need to make the holes .0005" under the size of the silver steel. So measure the silver steel first then set your reamer to cut as above. I would make a test hole first.
          #380343
          Speedy Builder5
            @speedybuilder5
            You would be very lucky to get an accurate fit by drilling. You would have to ream or accurately bore the holes. Again, you would have to measure the actual diameter of the shaft and from that select the correct reamer 'Fit'. However, most of us probably have the generic H8 reamer and instead of passing the reamer through the hole, just use the bottom end of the reamer (The tapered section) and by trial and error open up the hole to get the push fit you require. Note, not all lengths of silver steel are the same diameter – it is ground within limits.
            Imperial 1/4 to 1in ±0.00025 in
            #380351
            John Rudd
              @johnrudd16576
              You could make the holes undersize, then heat the parent metal to allow a sliding fit for alignment
              #380355
              Mick B1
                @mickb1
                Can you duck the issue with a tapped side hole and a grubscrew?
                #380360
                martin perman 1
                  @martinperman1
                  Its an antique butter churn which my friend drives with a stationary engine, we are replacing the rollers which the drum sits on so I would like it as original as possible so grubscrew wouldn't match the look I have adjustable reamers so I can ream to size, I wasn't sure of the tolerances.
                  Thank you,
                  Martin P
                  #380361
                  Hopper
                    @hopper
                    Could you turn the roller and axle protrusions out of one piece of 2.5" round material? Would save a lot of work.
                    #380381
                    martin perman 1
                      @martinperman1
                      Posted by Hopper on 12/11/2018 21:58:16:
                      Forgot to mention that the roller is made of brass. You have all pointed me to the right way, thank you.
                      Martin P
                      #380390
                      Chris Evans 6
                        @chrisevans6
                        Loctite 638 is your friend.
                        #380392
                        Ian S C
                          @iansc
                          I agree with Chris Evans, Loctite is by far the easiest way to go. You better make sure that the brass is lead free in a food environment.
                          Ian S C
                          #380395
                            Posted by martin perman on 12/11/2018 21:51:37:
                            Its an antique butter churn [ … ] I would like it as original as possible
                            Chris/Ian
                            I am [as you might expect] with you on the matter of Loctite 638
                            … But I assumed that Martin must have discounted it, on principle.
                            Edited By Michael Gilligan on 13/11/2018 10:10:00
                            #380396
                            martin perman 1
                              @martinperman1
                              Posted by Ian S C on 13/11/2018 09:58:00:
                              Ian S C
                              Thank you all again, Ian, I liked your comment about being lead free, the Butter churn will not see milk in it again as its purely for display only smiley
                              #380399
                              martin perman 1
                                @martinperman1
                                Posted by Michael Gilligan on 13/11/2018 10:09:30:
                                Chris/Ian
                                MichaelG,
                                Its a simple task and 638 is a simple solution, there are no serious loads involved and means making the job easier smiley
