Pigtail mop thread help
Home › Forums › Beginners questions › Pigtail mop thread help
  • #149133
    Jon Gibbs
      @jongibbs59756
      Another question please.
      I'd like to cut a threaded taper for a pig-tail mop mandrel but my lathe doesn't have either a taper attachment or a power cross-feed. It's a plain-old Myford ML7.
      I think I could do it by moving my tailstock over but is there another way because I'm hesitant to change the tailstock alignment as it's taken me a while to get it right on centre wink
      Any guidance or ideas would be very gratefully received.
      Many thanks
      Jon
      #7110
      Jon Gibbs
        @jongibbs59756
        #149138
        Keith Long
          @keithlong89920
          At under £6 inc postage and vat from RDG is it worth the effort of making one?
          #149139
          Robbo
            @robbo
            You should be able to get a long enough taper for a pigtail just by angling the topslide.
            #149141
            Ian S C
              @iansc
              That's right Robbo, but he wants a thread on the taper also, and you can't do that by angling the top slide. Go for the 6 pound one. Last time (only time) I did a thread on wood, I used a triangular file, no lathe. Ian S C
              #149142
              Bazyle
                @bazyle
                Aren't pigtails threaded? You need to be able to link the topslide handwheel to the gearbox/change wheels to thread at an angle. This could be done with a flexible drive. Interesting but not worth the effort.
                #149143
                Jon Gibbs
                  @jongibbs59756
                  Thanks all for the guidance and discouragement wink
                  – I didn't think it was going to be straight forward but thought it'd be a fun thing to try.
                  I already have a cheap pigtail on a 1/4" shaft but another one on an MT2 arbour would have been pretty handy.
                  Anyway, at least I have the satisfaction of knowing that I wasn't missing something obvious.
                  Thanks again
                  Jon
                  #149148
                  John McNamara
                    @johnmcnamara74883
                    Hi John Gibbs
                    If you have a boring head with a Morse taper that matches your tailstock? A cheaper Asian one will do; you can set it over to the required angle without disturbing your tailstock.
                    To use it make up a hard centre that fits in the tool holder hole in the boring head instead of a boring bar.
                    I don't particularly like hard centres so I made a small stubby Live centre that fits in the boring head hole as well.
                    I find it works rather well. The setup is a little less rigid, however for most work is fine, and it saves resetting the tailstock.
                    Boring head Images: **LINK**
                    Jon Gibbs
                      @jongibbs59756
                      Hi John,
                      Thank you for the suggestion. I did wonder about that possibility – possibly with a home-made offset centre based upon a blank-end arbour.
                      Is there a trick to ensure it stays horizontal in the morse-taper – A draw-bar through the tailstock perhaps?
                      Thanks
                      Jon
                      #149151
                      John McNamara
                        @johnmcnamara74883
                        Re Pigtail Mop Mandrel
                        Images: **LINK**
                        They all look constant pitch to me, only the diameter changes.
                        A while back I had to make a part for an antique for a friend it was a coarse spiral on a short tapered steel part.
                        The solution was to use a piece of springy steel about 8mm in diameter and 300mm long, this was held in the three jaw, the part (Centre drilled) was attached at the other end. Using the boring head I set it over to the correct angle, forcing the thin bar to deflect. Using light cuts and slow revs I was able to cut my spiral thread, The bar did not break. It worked…..
                        I guess this story only needs a bit of fencing wire to complete it. I will save the wire and that story for later!
                        John McNamara
                          @johnmcnamara74883
                          Hi Jon
                          My tailstock self ejects so I normally give the centre or centre drill a good shove when putting it in, it is 3 Morse taper. I keep it and all tapers that go into it scrupulously clean and almost dry so I get a good grip, I don't oil them, and just before I insert them I clean the hole with my finger and drag the taper on the tool through a clenched hand to check for any dirt.
                          The tailstock barrel is keyed so it cannot rotate and it has a lock to make it rigid, the turning forces should keep it against the key if it is loose in the key anyway and there is no lock. If your tailstock has a through hole you could use a draw bar.
                          I would not recommend this method for heavy or high accuracy work, the rigidity is not as good as using the tailstock. for small pieces it is fine.
                          I should have mentioned the boring bar movement axis should be horizontal, or you will not get a straight taper.
                          Jon Gibbs
                            @jongibbs59756
                            John,
                            Thanks very much. As you say the pigtail is not a precision taper/thread so a bit of movement will not be a disaster.
                            I will not use this for the Morse Taper.
                            Jon
                            #149176
                            frank brown
                              @frankbrown22225
                              When you make your pigtail blank, centre drill one end, for a chuck mounted centre and driving dog. Turn the other to have a 60 degree short point on it, this is your live centre. Jury rig a piece of steel with a countersunk hole in it (female fixed centre) at a suitable offset from the lathes centre line to make the front side of the pig tail parallel to the lathes axis. Back the tailstock up against it and grease the centre. And go for the thread!
                              Frank
                              #149210
                              Jon Gibbs
                                @jongibbs59756
                                Thanks Frank. Suggestions much appreciated.
                                Jon
                                #149227
                                Robbo
                                  @robbo
                                  Hi IanSC
                                  I'd let thoughts of the taper make me forget about the need to cut a thread on it. Ain't old age wonderful.
                                  #149248
                                  Ian S C
                                    @iansc
                                    Hi Robbo, the mop I mentioned, a wooden handle for a floor mop, I wasn't thinking engineering when I wrote up last night. Ian S C
