Pansy 5″ – boiler fixing
Home › Forums › Locomotives › Pansy 5″ – boiler fixing
  • #161089
    Phil Catchesides
      @philcatchesides15448
      Just got my boiler from Cheddar Valley Steam (absolutely superb workmanship) and am fixing it to the chassis. The drawing and articles just specify a push fit into the smokebox ring and the firebox end is on an expansion support. To me it seems as if the boiler can float backwards and forwards with expansion / contraction over time – can I / should I fix the boiler to the smokebox with, perhaps, a grub screw or 2 ?
      #1312
      Phil Catchesides
        #161094
        julian atkins
          @julianatkins58923
          hi phil,
          there is a vertical stretcher between the crank axle and front of the firebox, so the boiler cant move forwards, and the front of the rear hornblocks prevent the firebox moving backwards.
          when you have added everything else plus all the piping, plus brackets to hold down the expansion angle, i can assure you the boiler wont shift! (it is possible the above brackets arent shown on the drawings).
          if you secure the boiler to the smokebox you will have a hell of a job ever taking the 2 apart at some future date eg blanking off bits for a pressure test and the inevitable replacement of superheater elements if the loco sees lots of use.
          anyway ive never secured any of my boilers to the smokebox!
          cheers,
          julian
          #161705
          Phil Catchesides
            Thanks Julian – reassured
            Is there any insulating cladding on the boiler? Can't see any in the (rather poor) drawings but most locos do, don't they?
            Phil
            #163062
            wendy jackson
              @wendyjackson
              hi, there is no cladding on the boiler, there is no room for any due to the panel work. also the boiler once in place will not move at all. I used a bit of plumbers sealer between the boiler and smoke box just to make sure it was a good seal.michael
            Home › Forums › Locomotives › Topics
