Paint prep
Paint prep
Home Forums Beginners questions Paint prep
  • #454757
    Alan Wilkinson 1
      @alanwilkinson1
      Hi a query for you paint experts, I have made a traction engine steam chest from bar cast iron ,the covers are bronze, studs and nuts steel. what prep is needed for painting I Have high heat paint stove paint but it says nothing about priming or what ever The chest covers etc are bronze what do I need for them or would you just black the block and polish up the bronze ATB Alan
      #10095
      Alan Wilkinson 1
        @alanwilkinson1
        CI steam chest
        #454804
        Steviegtr
          @steviegtr
          If you are talking about stove enamel then. My Dad had an electrical shop & used to recondition the old Hoover vacs. The body was alloy. All he did was use a Alloy etch which was a yucky looking yellow stuff. Then paint straight on with no primer as such. I myself have been painting for many years but on cars & motorcycles. Not sure about painting onto cast. If you are using high heat paint then I cannot see any point in using a primer, as long as the parts are super clean. There must be someone along shortly to give you a definitive answer to this.
          Steve.
          #454812
          Graham Stoppani
            @grahamstoppani46499
            Dan Gelbart has some interesting things to say about surface prep. for painting on YouTube
            Den Gelbart: Building Prototypes part 6 of 18
            #454899
            duncan webster 1
              @duncanwebster1
              Posted by Steviegtr on 01/03/2020 00:02:27:
              Steve.
              Possibly zinc chromate primer, used to prime aluminium aeroplanes back in the olden times. I tried it on an aluminium garage door, didn't work all that well
              #454976
              Perko7
                @perko7
                More years ago than I care to remember I overhauled a side-valve Ford Prefect engine. Painted the whole block and head (both cast iron) with 'Engine Enamel' which was a supposedly temperature-resistant paint. Went on neat, no primer or undercoat required. I had already cleaned the block using kerosene and a stiff brush followed by soapy water. Paint was still in good condition when I foolishly sold the car 20 years later. Perhaps the vintage car and motorcyle owners in this forum could suggest a modern alternative?
                #455040
                John Rutzen
                  @johnrutzen76569
                  Great video Graham you posted a link to. I learnt more about why my paint doesn't stick from that than from anywhere else!
                  #455063
                  Dave Halford
                    @davehalford22513
                    You can get zinc spray primer that's good for 300C
