o-ring fitting
o-ring fitting
Home › Forums › Beginners questions › o-ring fitting
  • #65048
    rik arry
      @rikarry
      I need to know what size oring and groove i would need to seal a tube ..
      eg 16mm inside dia tube , with a 16mm plug..
      what size groove would i need in the plug to fit say a 2mm cross section oring
      and then what size dia o-ring would i need ..
      is there an on line calculator etc.. anywhere ??
      thanks in advance .
      #5433
      rik arry
        @rikarry
        #65050
        Les Jones 1
          @lesjones1
          Hi Rik,
          There was an article in issue 156 (Autumn 2009) of MEW about using “O” rings. That had information about groove sizes etc.
          Les.
          #65057
          rik arry
            @rikarry
            the best i could find so far is – http://www.prepol.com/hardware-selector.asp
