New member
New member
  • #462152
    Sam Spoons
      @samspoons83065
      Hi I've just started to get an old Boxford into working order so have joined the forum as I'll need advice and help. My last serious engineering was nearly 50 years ago at school and college so I'm very rusty but am reasonably aware of the safety issues (though if you want to remind me I won't take offence).
      #40757
      Sam Spoons
        @samspoons83065
        #462226
        David George 1
          @davidgeorge1
          Hi Sam welcome to the forum. Where are you based as it helps with local supliers and help. There are plenty of Boxford owners on here who can give advice. Safety DONT LEAVE THE CHUCK KEY IN THE CHUCK and Wear safety glasses. Good luck
          David
          #462234
          Chris Evans 6
            @chrisevans6
            Welcome along Sam, what sort of thing interests you to make on the lathe ?
            #462244
            Brian H
              @brianh50089
              Hello Sam and welcome. I'm a Boxford owner and I'll help if I can.
              A good source of info about all sorts of machine tools is;
              #462258
              Sam Spoons
                @samspoons83065
                Thanks guys.
                Thanks for the advice David. Will heed.
                Chris, I plan to use the lathe for odd jobs, first one will be to repair a brass double bass tuning machine with a snapped shaft, just a matter of drilling and inserting a pin down the middle. I'm not likely to become a serious model maker as my other hobbies* take up more than enough of my time.
                Brian, thanks for the link, I was aware of the website and it is a very useful resource.
                Getting the Boxford working is almost an end in itself. It won't be a 'restoration', I don't have the skills or the time/motivation but simply a 'fixing up' so I can have a functioning lathe at the end of the process.
                * Musician/guitar player, recording/retired live sound guy and sailing dinghies.
                #462275
                Sam Spoons
                  @samspoons83065
                  Just to add, I'm in South Manchester, very close to Abbotsfield Park.
                  #462287
                  Bazyle
                    @bazyle
                    Sam. Enjoy your Boxford.
                    The screw in the middle of the star wheel on the front of the apron on a Boxford is reverse thread. The clutch that this works is not meant to allow you to let it slam up against a saddle stop, It should be tightened enough to make the cut but you should be able to grip the handwheel and stop the saddle just shy of the saddle stop so it contacts gently
                    The grub screw going in from the right hand side of the apron to hold the half nut lever may be a locking screw with another one deep beneath it.
                    Don't forget to oil the backgear layshaft, and the pulley when in back gear mode, and the groove just in front of the bull wheel that the engagement slider works in. Slight risk of dropping the bits but consider taking off the front backgear engagement lever to see if the brass shoe that fits in that groove is not completely worn down.
                    Don't use the backgear for freeing the chucks.
                    #462300
                    Sam Spoons
                      @samspoons83065
                      Thanks Bazyle, I've started a thread in the Beginners Questions forum about fixing up my lathe as it seems the best place for it.
                      #462306
                      Steviegtr
                        @steviegtr
                        Welcome Sam. Lots of Boxford owners on here. Good luck with your refurb.
                        Steve.
                        #462309
                        Sam Spoons
                          @samspoons83065
                          yes
                          #462366
                            Welcome to the forum Sam,
                            Anything on Soundcloud or Bandcamp?
                            Sam Spoons
                              @samspoons83065
                              Not at the moment, just for fun really. I'll see if I can dig soon live stuff out.
                              Do you play?
