Myford ml7 clutch
Myford ml7 clutch
Home › Forums › Beginners questions › Myford ml7 clutch
  • #47506
    Stephen Middleton
      @stephenmiddleton53822
      Hello,
                I am new to the forum and as an old engineer (28 years ago) I am trying to pick up the threads again for my retirement.
      Does anyone have copies of the drawings for the clutch that apparently came with issue 5.
      Any info would be most welcome.
      Thanks,
                    Steve.
      #4923
      Stephen Middleton
        Model Engineers Workshop Issue 5
        #47512
        Jim Whetren
          @jimwhetren72358
          Hello Steve,
          It just so happens this was the first MEW issue I bought, and as I don’t have a Myford, I only gave the plans a passing look.
          What was it you wanted to know?
          Jim
          #47522
          Stephen Middleton
            Thanks Jim,
                                 What I am looking for is a copy of the plans,the background info is in the digital archives and I can print that off.
            Thanks for your reply,
            Steve.
            #47528
            Jim Whetren
              @jimwhetren72358
              Hello again Steve,
              I have sent you a message with my e-mail address so we can make contact outside of the forum.
              Jim
              #47532
              KWIL
                @kwil
                I have the plans also if required, they would scan to 10 off A4
                #51327
                Michael Wilde
                  @michaelwilde12011
                  Hi, would it be possible to get a copy of these plans?
                  Many thanks
                  #51334
                  Jim Whetren
                    @jimwhetren72358
                    Hello Mike,
                    I have sent a PM.
                    Jim
                    #94922
                    Adam Wells
                      @adamwells85667
                      Hey, I know this is an old thread, but could I have a copy the plans? Thanks
                      Adam.
                      #108343
                      Richard Fallas
                        @richardfallas88897
                        First post to MEW forum.
                        As per Adam's last post, is it possible to get a copy of the plans? I have printed out the article, but drawings would make life easier.
                        Have acquired a 60yrs younf ML7 which means it is slightly older than I am, but its original Hoover motor is telling that I need a clutch!
                        Can anyone help please?
                        Thanks
                        Richard (NZ)
                        #108406
                        John C
                          @johnc47954
                          Hi Richard,
                          PM me with your e-mail address.
                          Robbo
                            @robbo
                            Hi all,
                            I scanned these drawings a couple of years ago for a chap in Australia, still have the files in pdf, so can send them, subject to server capacity, in short time.
                            If anyone would like a set, send me a PM with email address.
                            Phil
                            #108466
                            _Paul_
                              @_paul_
                              @Robbo PM sent
                              Thanks
                              Paul
                              #108622
                              Richard Fallas
                                @richardfallas88897
                                Thanks for all responses. Really helpful for a new member.
                                Have PM'd to John.
                                I've known about (and lusted after) Myfords since I was 14 (Model Engine Encyclopaedia, c1968), and now I have one. Having used a Unimat for 25 years or so for modest sized stuff, its great to have the bigger machine. But size isn't everything and I have a lot of learning to do. In fact the reason I didn't go Chinese (was looking at Seig SC4 and 6's) was mainly that I knew I would be tapping into decades of accumulated wisdom. Seems I was right.
                                Meanwhile if anyone is remotely interested in what can be done on a Unimat there is an entry in the Gallery on the Model Engine News Dec 2012 page. I am now working on a Mills 075 replica which will have benefitted from both Unimat and Myford. Will broadcast more when finished.
                                Thanks again.
                                Richard
                                #108840
                                Robbo
                                  @robbo
                                  Ken,
                                  I have replied to your PM. I need your email address to send the drawings.
                                  Phil
                                  #108948
                                  Richard Fallas
                                    @richardfallas88897
                                    Thanks to John C I now have the drawings.
                                    Puzzled by what actually causes the clutch to stay engaged ie spring to force cone into ring. Maybe that will be clear when I print out the dwgs. I can see the small spring providing return pressure for disengaging shaft, but not what forces the clutch closed again. Anyone care to explain? Probably very obvious!
                                    Cheers
                                    Richard
                                    #134981
                                    Kevin F
                                      @kevinf
                                      Sorry for raking up an old thread,but does anyone have the drawings for the ML7 clutch system, I would like to incoperate the ML7 system onto my ML4 ,thanks in advance .
                                      Edited By Kevin Fenrich on 09/11/2013 10:04:59
                                      #135000
                                      KWIL
                                        @kwil
                                        Kevin,
                                        PM your email and iI will send you scanned copies
