myford metric thread cutting
Home › Forums › General Questions › myford metric thread cutting
  • #119691
    Matts BitsNBobs
      @mattsbitsnbobs
      Hi can anyone tell me the issue number or month and year of MEW magazine that covered Derek Browns conversion of a Myford S7B to cut metric theads?
      Thanks in advance,
      Matt.
      #22624
      Matts BitsNBobs
        @mattsbitsnbobs
        #127523
        Murray Tricker
          @murraytricker65189
          Try Harold Halls index at http://www.homews-mew-index.co.uk
          #127537
          Brian Wood
            @brianwood45127
            Hello Matt,
            The issue you want is June 2011 MEW 177.
            Regards Brian
            #127539
            Gray62
              @gray62
              Issue 177 has the article Metric Screwcutting without tears by D.A.G Brown
              Graeme
              #127541
              John Stevenson 1
                @johnstevenson1
                Seems a lot of work to me when you can do the same with one gear to be changed.
                #127555
                Matts BitsNBobs
                  @mattsbitsnbobs
                  Thanks for the replies guys, will have a look later,
                  Regards Matt
                  #127579
                  Geoff Rogers
                    @geoffrogers81118
                    hi John,
                    I am sure you have said before, but which gear?
                    Geoff
                    #127580
                      33 or 34 see here
                      #127586
                      Phil P
                        @philp
                        Posted by John Stevenson on 22/08/2013 09:11:19:
                        I have just been doing a load of metric threads on some collets and DA chucks for my Boley/BCA jig borer. I had just finished setting up the metric gear train as per the chart inside the cover when I remembered the 33/34 trick, so I changed it all back to that set-up and it works a treat, along with the Meek screwcutting clutch it is so simple and quick to cut metric now.
                        Phil
                        #127598
                        Roderick Jenkins
                          @roderickjenkins93242
                          I'm glad to see that there is a least one believer. The maximimum error in any thread using this system is 6 microns, that's 6/1,000,000 metres or 6/1000 millimeteres. Sadly, many people have unrealistic expectations of both their machines and their abilities and believe that any error is unacceptable – hence the oft quoted insistance that the only "correct" way to make metric threads on an imperial lathe is by using a 127 tooth changewheel. Relax, as Phil has shown; it's good enough!
                          cheers,
                          Rod
                          #127650
                          Geoff Rogers
                            @geoffrogers81118
                            thank you Roderick for the tables in the other post. just the job.
                            6 microns – easy to work to if you happen to have a couple of millon pounds worth of kit, but not what you would find in the avearge shed.
                            Geoff
