Myford belt Tension Lever Stuck!
Home Forums General Questions Myford belt Tension Lever Stuck!
  • #361470
    robert willoughby
      @robertwilloughby50901
      Hi i'm Robert. I got 70s myford lathe. I stupidly changed the belt to different pulleys to change speed, without loosening the tensioner. Succeeded. Then the tension lever would not loosen and won' start!
      Can anyone advise me what to do?
      I cannot understand why this has happened!
      Robert
      Edited By JasonB on 10/07/2018 14:15:54
      #26083
          I've put your question in a new thread which should get you a few more replies.
          J
          #361475
          KWIL
            @kwil
            Which Myford lathe model?
            #361476
            Martin Connelly
              @martinconnelly55370
              Get the belt onto a smaller pulley to relieve the tension then see if the lever works and if the motor starts.
              Martin C
              #361477
                Posted by JasonB on 10/07/2018 14:17:21:
                I've put your question in a new thread …
                Phew … that's O.K. then, Jason
                … When I saw this thread, with your name; I thought there had been a Damascus event !
                Robbo
                  @robbo
                  As Martin says, take the tension off the belt by moving it to a smaller pulley. If you can't move it then slacken off the tension adjusting screws on the swing head. Then see if the tension lever works and the motor runs
                  Edited By Robbo on 10/07/2018 15:04:51
                  #361504
                  Grizzly bear
                    @grizzlybear
                    Robert,
                    Is there a safety switch on the belt guard, that you may have disturbed?
                    Bear..
                    #361592
                    Ian S C
                      @iansc
                      (Safety switch)Doubt it Bear, it's a Myford.
                      Ian S C
                      #361596
                        Even a belt guard is doubtful let alone a safety switchsmile p
                        #361680
                        Grizzly bear
                          @grizzlybear
                          Thank you, Ian & Jason. Your replies made me smile!
                          I mentioned safety switch, due to the fact it wouldn't start.
                          You learn something new every day!
                          Bear..
