Looking at the original Purple Poison both brake rod and gear-lever connection rod are still bent. Less than the modified version but still enough to make control more than iffy.
Frankly I can't be doing with this sort of "look at the pretty (?) paint job ignore the crap engineering" thing. The perpetuators have worked quite hard to produce something pretty much unrideable over any distance.
Picking up on the Manxman pictures if you want rare with a Norton badge on the tank here is mine :-
Rotary engined Supreme Commander. 7 or 8 only I think. Started out as an ordinary Commander Krauser , around 100 of those about, then extensively, ahem, expensively modified with modern suspension et al by Richard Negus. Junking the Yamaha XJ900 running gear and brakes means that it stops if need be and has normal big bike handling not the standard "trail bike in super tourer disguise" version. Hafta say I rather liked the standard lively handling but it got the stopping problem sorted about a week after delivery with a set FJ1200 4 pot brakes up front. Had on before and figured out that mod pretty early. Now working on his second 100,000 miles "Grandad" (christened by my kid sister 'cos he is big, grey and sometimes smokes a bit) still has a more than adequate turn of speed when needed to put the explosion in paint factory leathered brigade in their place. Comfy behind the big fairing but speedo watching is essential as he thinks 90 mph is a nice relaxed cruising speed!
Anyway I like different, so long as it works well.
This Yamaha GTS shares garage space with the Norton. About 100 originally imported I think. My 65 th birthday present from me to me. Put 60,000 odd miles on one back in the day before an "I'm sorry I didn't see you incident" and liked it. So I gave into temptation. That one has less than 11,000 miles since new in 1994. Why spend all that money and not use it? The funny front end system works really well once you figure out that it its all done by counter steering. Lean (hard) on the bars and it goes where it should with militant indifference to road surfaces. Just don't forget the pathetic steering lock and excess weight. Fuel injected EXUP motor defenestrated to 100 bhp is the worst feature as its pretty gutless and needs too many revs for my taste.
Couldn't be more different to the flat torque curve and seemingly endless power delivery of the big rotary.
Edited By Clive Foster on 23/08/2019 16:01:14
