Motorcycle General Discussion
Home Forums Related Hobbies including Vehicle Restoration Motorcycle General Discussion
Viewing 25 posts - 601 through 625 (of 1,161 total)
  • #353732
    Trevor Crossman 1
      @trevorcrossman1
      Posted by Ian Parkin on 12/05/2018 17:06:58:
      Today a neighbour asked if i wanted to rebuild this for him ?
      so in my back yard I now have a huge jigsaw of many boxes of bits
      Ooo a Comet! That'll be a nice project though I hope that you get the mag timing better than on my pal's Comet back in the '60's, it sometimes had a real mean kick-back if one didn't jump on the kick starter with every ounce of my massive nine stone frame!
      john fletcher 1
        @johnfletcher1
        Hello Phillip, re your sons Power Pack. Obtain a 6 or 12 volt motor cycle ignition coil, connect the battery negative to earth/frame, connect the positive to the + terminal on the coil, connect the negative terminal of the coil to the contacts/points (the wire)and other side of the contact mounting plate to earth/frame. One long series circuit, when the points are closed current can flow in the primary of the coil and as they open spark is generated from the HT lead. Check that the condenser, now called a capacitor is OK, if its faulty you won't get a spark, it connect across the points, replacements are available. For a simple condenser check, connect it across 12 volt battery and when you remove it from the battery and connect the lead to the metal canister there should a spark.Make sure the points are clean and correctly adjusted using feeler gauges.John
        #353793
        Philip Burley
          @philipburley44197
          sounds logical , The condenser on the mimi Wypac flywheel mag is a brass tube behind the points , I can feel a bit of a shock but not enough to generate a spark , I expect after 60 years the insulation has broken down , So I will find a small Honda style coil and condenser and see what I can come up with , Thanks for explaining in simple terms how to do it . My cars have been diesels and my mower is electronic , Regards Phil
          #353794
          Philip Burley
            @philipburley44197
            thinking about it , I suppose it might be worth changing the condenser first , see what that does , as I would still have to get one anyway
            #353806
            John Olsen
              @johnolsen79199
              The condenser for a magneto is sometimes a different capacitance than what a battery and coil system needs. That does not mean that either system would not work with the wrong one, but they tend to work better with the right one. Of course they don't always label them with the actual capacitance so it can be hard to tell.
              john
              #353828
              Ex contributor
                @mgnbuk
                Might be that the flywheel needs remagnetising, rather than the condensor ?
                Nigel B
                #353845
                Ian S C
                  @iansc
                  I agree with Nigel, with magneto ignition, specially old stuff the magnets are likely a bit down. They can in a lot of cases be remagnetised.
                  Even without a condensor you should get a good belt off the magneto even if turned by hand.
                  Ian S C
                  #353894
                  Meunier
                    @meunier
                    Posted by Trevor Crossman 1 on 12/05/2018 17:57:49:
                    Ooo a Comet! //
                    Oooh a Comet – I also thought – until realising it was definitely not the same Comet as the James 98cc Comet I learned to ride on at age 14 !
                    DaveD
                    #353938
                    Windy
                      @windy30762
                      Been some sand record breaking at Pendine today
                      Zef Eisenberg first man to do 200mph+…201.573
                      #354493
                      thaiguzzi
                        @thaiguzzi
                        Posted by Hopper on 17/04/2018 10:45:14:
                        Posted by thaiguzzi on 11/03/2018 06:33:58:
                        Always liked the Sportster motor in a Featherbed frame. Fills the space nicely, and, IMHO looks a better fit than any Brit parallel twin. Just looks "right".
                        It fills the new Featherbed frames they are making that are an inch or more taller than the originals. Sporty engine in an original Featherbed frame has the rocker boxes half hidden up under the tank, between the top frame rails and always looks oversized to me. I built one with an Ironhead Sporty motor back in the 80s and getting the engine in the frame consisted of lie engine on side on garage floor, finagle frame top rails down over rocker boxes, set bottom rail on the oil pump, jump on frame to spring it past the oil pump and into position, then stand the lot upright and make engine plates using technique similar to building ship in bottle for the rear mount.
                        I also have a 45 Flathead motor in a Featherbed, which to me looks much more correctly proportioned. But nowhere near as much barn-storming fun! (Until I get around to putting the stroker flywheels and Leinweber cams in it.)
                        Excellent description. Concur with everything written.
                        Some good posts in this thread whilst i've been away (family holiday in Blighty).
                        #355336
                        JimmieS
                          @jimmies
                          #356189
                          Mike Poole
                            @mikepoole82104
                            What are these men made of? **LINK**
                            https://www.bbc.co.uk/sport/motorsport/44083363
                            As a spectator I made 7 visits to the TT and loved every minute of it (almost). Everyone who races and watches Road Racing knows it has its dark side but as a spectator I think it has no equal and it must have something that draws the riders to a race they know has great danger. Some race just to pit themselves against an unforgiving circuit and complete the race, some will have the skill, machinery and luck to win a race. I take my hat off to all of them. Many GP racers take a look and say not for me and I suspect many are contractually forbidden to race there these days.
                            #356191
                            Barnaby Wilde
                              @barnabywilde70941
                              Posted by Mike Poole on 02/06/2018 11:21:32:
                              They're not scared of dying, they're scared of failing.
                              I've broken through that barrier of 'what if' & let the adrenaline take over a few times. If you've never been there, either a dangerous sport or a situation going horribly wrong, I cannot explain just how exhilarating it feels. Adrenaline is the strongest & most dangerous drug there is, it's killed & maimed more than all other drugs put together x10.
                              You can never feel truly alive unless you are this <> close to death.
                              Putting that aside, it does seem that more than a few of 'em are not quite wired up the same as the rest of us mere mortals.
                              #356200
                              Mike Poole
                                @mikepoole82104
                                I have on occasion thought about why motorcycling in general is exciting and I tend to come up with the answer that it is dangerous and you are very much in control of how dangerous it is. As you gain experience on a bike the odds do move in the right direction but too many people make a mistake you can't learn from. I think if you start at 17 and reach 25 alive you are in with a good chance or surviving on a bike, you will have honed your powers of prediction and roadcraft and the brain will be in contol of the throttle and not what you keep in your trousers. Unfortunately the brain can lose out to the trousers occasionally even with very experienced riders. I remember that a brain shaped piece of wood was in the pits at the Bol d'or and I think it was labelled Roger Marshalls Brain while he was out doing a session. Maybe Road Racers brains have an off switch or they just run on trouser control.
                                #356219
                                Chris Evans 6
                                  @chrisevans6
                                  I started riding at 16 and will be 70 in a few weeks, in all that time I have never been without a bike. There is nothing to compare for me. I still often go to Norther Ireland for the road racing, the most exciting in the world.
                                  #357363
                                  JimmieS
                                    @jimmies
                                    From Manx Radio site
                                    MHK wants as much data as possible
                                    The politician leading a study on the economic impact of the TT and Festival of Motorcycling wants to hear more from businesses and individuals alike.
                                    The first part of the report, which focused on the money government spends on and makes from the two events, has just been released.
                                    It revealed a net loss of £950,000.
                                    Part two, which should reach Tynwald by January next year, is still being worked on.
                                    #357367
                                    Frances IoM
                                      @francesiom58905
                                      re TT – the sum of ?950k lost is merely the tip of an iceberg, for as many have been questioning for years, a very large amount is ‘hidden’ in the costs of other departments – also consider that with finite (and declining) budgets the 50+% spent on maintaining the TT course to race standards requires significantly less to be spent on the other vast majority of roads – also note that the costs of fatal + other serious accidents are ignored (eg this year was better than usual as only one visitor was killed (and that in a supposed speed restricted road) – I like many others find it safer to be off Island whilst the carnage takes place.
                                      #357741
                                      Windy
                                        @windy30762
                                        And now for something completely different. This guy is the holder of the British and Commonwealth bicycle speed record of 114mph – Neil Soupy Campbell. He intends to go one further and break the European record 127 mph during Straightliners top speed & wheelie Tuesday the 19th June at Elvington!
                                        Remember online entries close Friday night. £25 extra after that. Here is the link https://http://www.straightlinersonline.co.uk/events/event/117-top-speed-tuesday-19th-june.html
                                        Taking place Elvington Airfield, North #Yorkshire, England. Photo Adam Roberts. Please share and like this post and don't forget to follow us. #topspeed & #wheelie
                                        #358500
                                        Windy
                                          @windy30762
                                          Another good day at Elvington with fast record 135mph push bike and very fast motorcycles.
                                          Fast lass Becci did 248mph as I left.
                                          Edited By Windy on 19/06/2018 20:35:10
                                          Edited By Windy on 19/06/2018 20:39:13
                                          #361151
                                            Mike Poole
                                              @mikepoole82104
                                              Yet another tragedy for the Dunlop family. The 1977 film Roadracers sparked my interest in road racing, the three stars of the film are all dead and all in racing accidents, RIP Frank Kennedy, Mervyn Robinson and Joey Dunlop. I love road racing but it wreaks havoc on the families of the young men who die for very little reward. Motor cycling is not the only dangerous sport and as usual there will be calls to ban it. We should resist the nanny state as humans need to do dangerous things, even as kids we climb trees, see how fast we can go on our push bikes etc. I think part of the thrill for a road racer is to beat the circuit as well as the other competitors, many of the racers at the IoM TT are there to pit themselves against the fearsome TT course and have very little chance of winning the race but just taking on the circuit is enough. I wonder if as a spectator I encourage these men to risk all or would they do it anyway even if nobody watched? Racing motorcycles has probably been going on since the second machine was built but even when you are riding on your own you see if you can go that little bit quicker than last time, you are always looking for a personal best for something.
                                              #361205
                                              Ian S C
                                                @iansc
                                                Even 75 years ago kids were getting into fast things and getting killed. and a good many had never driven a car or motor cycle, or had a licence. They were climbing into a Spitfire, or a tank, there was adventure, and the kids today still need the adventure.
                                                Ian S C
                                                #361207
                                                Hopper
                                                  @hopper
                                                  Sad to hear that. It does remind me of the old anecdote though:
                                                  When was the first motorcycle race? As soon as the second motorcycle was made.
                                                  #361251
                                                  ronan walsh
                                                    @ronanwalsh98054
                                                    I do love motorcycles, but they are dangerous bloody things.
                                                    Edited By ronan walsh on 08/07/2018 18:13:11
                                                    #361284
                                                    colin wilkinson
                                                      @colinwilkinson75381
                                                      Ronan, sorry, motorcycles are inanimate objects until a human sits on it. I have just spent today at Mallory Park on my Greeves Silverstone and it was only as dangerous as I made it. It was only a "parade" but it was as fast as I could go given my age and self preservation. Having raced in Ireland in the 60s and 70s and them Isle of Man it is purely a self challenging and determination to be better than my fellow man not a look at me attitude which seems to prevail today. Colin
