ML7 = Change Wheels have plain bore
Home › Forums › Manual machine tools › ML7 = Change Wheels have plain bore
  • #104498
    Simon B
      @simonb
      The ML7 I have came with 4 or 5 change wheels of varing size – ok so far.
      However, they are all plain bore, none have a keyway. Does this sound correct?
      Simon
      #12046
      Simon B
        @simonb
        Key?????
        #104499
        John Stevenson 1
          @johnstevenson1
          Do they have a small dowel hole in them ?
          If so then they are off the earlier ML2 and ML4 series.
          #104502
          Simon B
            @simonb
            The knowledge here is really scary – instant and spot on!
            John, yes they do! Unless you are going to tell me they are a real rarity and worth a fortune, do you know off hand if they share a common bore in which case I could get a keyway machined?
            Thanks, Simon
            #104504
            John Stevenson 1
              @johnstevenson1
              Identical gears to the ML7, in fact there were some produced that had the dowel hole and keyway, probably using up old stock.
              You just need a 1/8" keyway broaging into them.
