Minnie problem maybe solved
Home › Forums › Help and Assistance! (Offered or Wanted) › Minnie problem maybe solved
  • #256043
    David Bothwell 1
      @davidbothwell1
      Upon inspection I have found that the regulator on my engine was stuck and although I am not 100% sure,but I think it was in the closed position. I ythink this will explain why there was no pressure behind the piston! It also looked as though there was rust on the regulator rod, as I did not make this part I think this was mild steel, I will not be able to go back to the engine until Saturday a.m. but I would appreciate any comment on this saga!!!sadangry 2
      #32785
      David Bothwell 1
        @davidbothwell1
        “stuck regulator”
        #256051
          The stuck regulator would explain why it would not go but if stuck shut the air should not have got past it and out the exhaust unless that was before the passage was plugged.
          Stainless would be better for the rod, at least the bit that actually goes through the gland, the longer length back to the lever can be mild steel. One easy way to tell is to put a magnet on the rod, if it won't stick then more than likely stainless though a few grades are magnetic.
          #256221
          David Bothwell 1
            @davidbothwell1
            Many thanks once again Jason. We have been out today, but I have been looking through my Model Engineer articles and I have noticed on the drawing for the slide valve housing there is a hole which is prominent (just above the exhaust and is drilled into the regulator passage.) In my valve housing the hole looks misplaced and has been made so that the wall of valve obscures quite a lot of it. Could this be a cause of enough air entering the valve chest?
            #256223
              That is the main route for the steam once you have opened the regulator it lets it flow down into the valve chest and then into the exposed port.
              If it is being obscured by the slide valve there is quite a hgh possibility that the air is going from this hole into the cavity on teh underside of teh valve and then straight to exhaust.
              Before you refit the cylinder would it be possible to post a couple of photos of the underside of the cylinder and also inside the valve chest, may be able to spot any other "unique" features that your engine may have.
              #256224
              David Bothwell 1
                @davidbothwell1
                Many thanks again Jason, but the hole is higher (not under the slide valve but (mostly) under the wall of the valve chest, quite a bit away from where it shows it is on the drawing in the ME article. I will post pictures as you suggest, may need to charge battery and remove the cylinder from the boiler.
                #256456
                David Bothwell 1
                  @davidbothwell1
                  I tried to upload the picture taken of the valve chest, nuiscance was that it was Nikon raw, converted it to JPG, then ree-sized, tried to upload the finished product but try as I may it would not go. I can say the valve and buckle werea bit shoddy soI have spent today re making these. I will try again with the picture. I can see after measuring the walls of the valve chest are oversize.
