Metal Bandsaw – quality?
Home › Forums › Workshop Tools and Tooling › Metal Bandsaw – quality?
Viewing 25 posts - 1 through 25 (of 29 total)
  • #335668
    Matt Harrington
      @mattharrington87221
      Hi,
      Has anyone any comments on this bandsaw.?
      https://www.ebay.co.uk/itm/AMA1140-Portable-Metal-Cutting-Band-Saw-1500W-Motor-Swivel-Base/272875290995?hash=item3f88a28173:g:kzYAAOSwt5tZ1kff
      I'm looking for something compact and this seems to fit the bill. Just not sure of the quality.
      Matt
      #18799
      Matt Harrington
        #335671
        Journeyman
          @journeyman
          It's an Amadeal machine. You will get it £25 cheaper direct from their site *** Amadeal *** cannot comment on quality though. Similar style to the Femi model which will set you back a few more quid but is reported to be very good.
          Matt Harrington
            Thanks John, That is useful to know.
            Hopefully someone may have bought one and can comment.
            Matt
            #335684
            nigel jones 5
              @nigeljones5
              Ive not got that one but ive got a similar small one somewhere in the workshop. Mine wont cut in a straight line to save its life, ive tried every adjustment on the planet to no avail. Also beware the blades are prone to snapping due to the very tight radius of the guide wheels, having said that if its Amadeal its probably a ton better than the one ive got and having dealt direct with the chaps at Amadeal I can vouch for their brilliant service.
              #335685
              KWIL
                @kwil
                Of course its cheaper direct from Amadale, ebay want their share.sad
                #335694
                  You will also have to pay a an additional delivery charge if buying Direct
                  I went for a Femi 782, cuts as straight as a die.
                  #335698
                  Journeyman
                    @journeyman
                    Not at the moment apparently, this from Amadeals site:-
                    FREE UK POSTAGE FREE UK POSTAGE FREE UK POSTAGE!!
                    (Excluding Islands, Scottish Highlands and Northern Ireland)
                    UK postage is now free except for the following postcodes BT, IM, JE, GY. HS, PA20 +, PH16 +, ZE, IV 1-29 and IV34 +, and KW
                    Shipping to the Highlands / Islands and Northern Ireland is an additional £6.50 up to 25kg
                    Matt Harrington
                      Unless I'm missing something, the Femi 782 is almost double the price!
                      THanks for the vote of confidence on Amadeal service.
                      Matt
                      #335720
                        Maybe that is what it costs to get one that will cut straight wink
                        #335722
                        Matt Harrington
                          Ha! I hope not! frown
                          Matt
                          #335728
                          Michael Briggs
                            @michaelbriggs82422
                            I have been considering buying a bandsaw for some time. After a near miss last week with a slitting disk I took the plunge and bought a Femi from Stakesy's. It cut straight without adjustment, wish I had bought one earlier. Whatever you go for check the price and availability of replacement blades.
                            #335729
                            Matt Harrington
                              Michael, thats quite a bit cheaper.
                              What blade tpi do people recomment for general purpose sawing of FCMS etc
                              Matt
                              #335764
                              MK_Chris
                                @mk_chris
                                @ Michael.
                                +1 from me for my 782XL saw, and for the supplier, and also for “the wish that I had bought earlier”. I also bought the vertical table accessory – the main use so far. Being able to lift it and move it about for convenience was also a plus. Happy with the blade as supplied.
                                Until I talked to the supplier I had not realised that the 782XL was a hand feed machine: not auto.
                                Planning to try an adjustable bar and weight on the head when larger cuts are required.
                                When it comes to any significant purchase my long held philosophy is :-
                                I have never regretted my extravagances but I have often regretted my economies. So yet one more for the “no regrets” column.
                                Chris.
                                Edited By MK_Chris on 07/01/2018 18:01:40
                                #335779
                                Michael Briggs
                                  @michaelbriggs82422
                                  Hello Chris,
                                  I have never regretted spending probably more than I should for a quality piece of kit. On the other hand buying cheap and buying twice has been a bitter experience on more than one occasion in the past. I would explain but I am trying to forget those mistakes. Michael.
                                  #335807
                                  Robbo
                                    @robbo
                                    You could also consider the lower spec Femi 780 XL (2-speed as against the variable electronic of the 782) on Amazon for about £300 delivered. LINK **LINK**
                                    Not much more than the Amadeal. I would want to check the angle cutting of the Amadeal, the geometry looks wrong and there is no picture. Maybe just the picture angle.
                                    #335875
                                    Robbo
                                      @robbo
                                      Posted by Matt Harrington on 07/01/2018 16:27:40:
                                      Matt
                                      As usual with bandsaws the thicker the material the coarser the blade pitch that can be used. But for everyday on mild steel I manage with 14 tpi, going to 24 tpi for thin sheet. Both these are commonly available.
                                      Notice that the Femi saws run faster than the Chinese imports, the 2-speed offering 60 or 80 metres per min, whereas my Chinese offers 20 (Stainless,Bronze, & other hard stuff), 30 (the usual mild steel), or 50 (Ally,Brass,Copper) mpm
                                      #335879
                                      ega
                                        @ega
                                        Am I right in thinking that the Femi blade runs in the opposite direction to the conventional 6 x 4 convertible machine?
                                        At first sight this seems unlikely if it means that the blade cuts upwards and away from the accessory table but no doubt a user can enlighten me.
                                        #335882
                                        jimmy b
                                          @jimmyb
                                          I too went a quest for a compact bandsaw, a few years ago. I ended up buying one of these **LINK** worth every penny.
                                          Not regretted it
                                          jim
                                          #335884
                                            Femi blade travels towards the pivot point same as other bandsaws and will therefore cut downwards when used with a table.
                                            Femi come with Vari pitch blades and mine is still goingstrong after 14months though I did buy a spare just in case.
                                            #335893
                                            Spurry
                                              @spurry
                                              I've had the Femi 2 speed for many years. I first saw it demo'ed at one of the ME shows at Ali Pally. The vendor was cutting 1mm slices from a circular bar of 50mm steel….
                                              Pete
                                              #335909
                                              ega
                                                @ega
                                                JasonB:
                                                Thank you for putting me right; I had speculated that the supposed difference might be to do with the handfed versus gravity fed point.
                                                There is a video on this page:
                                                https://www.stakesys.co.uk/femi-782xl-swivel-head-portable-bandsaw-230-volt
                                                which seems to show a direction of travel arrow on the saw frame pointing the "wrong" way (I coudn't detect from the demo which way the blade was actually moving but it seemed to be depositing the bulk of the chips on the operator side.
                                                #335921
                                                  EGA, I think you are right, some of the bigger saws do cut the opposite way, the NG series seem to be the ones, this video shows it better.
                                                  But the 780 and 782 which most of us seem to have cut the usual way
                                                  #335922
                                                  Michael Briggs
                                                    @michaelbriggs82422
                                                    Ega:
                                                    The video is of a NG120 which runs in the opposite direction to the 782xl, Femi claim it cuts 60% faster. It may be faster but you lose the option of vertical operation with a table.
                                                    Jason replied while I was typing ….
                                                    Edited By Michael Briggs on 08/01/2018 16:12:24
                                                    #335928
                                                    ega
                                                      @ega
                                                      JasonB and Michael Briggs:
                                                      Thank you – yet more points for the intending purchaser to think about!
                                                      The NG120 is obviously a bigger, more powerful machine but presumably the reversed direction also plays some part in its faster cut. The difference between Western and Japanese handsaws comes to mind but I don't think this is the answer.
                                                      In either case, the speed of cut is impressive but I shall be sticking to my ancient 6 x 4 and the associated cup of tea!
