mechanical luricator
Home › Forums › Beginners questions › mechanical luricator
  • #137899
    michael burton 1
      @michaelburton1
      hi i have my model running on air and have put to use my mechanical lubricator the was on enougher model,
      now the question is were is the best place for the oil to be put
      a) into the steam inlet pipe
      or
      b) directly into the reg chest
      or
      c) somewere else
      also as to the size of pipe to use i have 3/16 pipe and quarter pipe or do i need a much smaller diameter,the cylinder bore is around 1 3/8 and a 2'' stroke
      hopeful for some advice mike
      #6975
      michael burton 1
        @michaelburton1
        #137902
          Mike does your traction engine take its steam directly from the boiler up through the cylinder to the regulator chest or does it have a separate take off from the boiler that feeds steam to the regulator chest?
          J
          #137922
          michael burton 1
            @michaelburton1
            Hi Jason it has a separate pipe that takes the steam supply to the reg chest
            #138040
            michael burton 1
              @michaelburton1
              also while were here would the saftey valve go on to the boiler like a locomotive as im using a steam take off pipe to the reg chest or on top off the reg cover like traditional traction engine just so i can make a bush and get it fixed onto the cover while im there
              #138041
                You should be OK taking the steam to the regulator chest as it has a separate steam feed. The usual setup on a traction engine is to have the regulator chest linked to the boiler so if you put oil in there you risk it finding its way back to the boiler.
                1/8" OD pipe would be sufficcient for the oil supply, worth adding a non return valve in the run.
                Without seeing your setup I would say take it off the boiler as your steam pipe may restrict the escaping steam but check with your boiler inspector as they will have the final say.
