Hi, I have made a rotating turntable for making a telescope mirror. The turntable needs to rotate evenly with very little or no runout.
I was getting a lot of runout. I have figured out that this is due to the 8 inch pulley I have used to attach the shaft to a the wooden turntable I made, which is 20 inches in diameter. The pulley fits well on the shaft. However, the top of the pulley where I attach it to the turntable is unven, one side is higher than the other.
I am trying to make the pulley even by attaching a file to a vice, leveling it over the pulley and rotating the pulley on the shaft, using a motor at. around 25 rpm. This seems to be working, slowly. The pulley is metal, I am not sure what metal.
My question is, is this a good way to do it? Of course the file is going up and down with the motion of the pulley as it goes round.
I have a milling machine but no lathe.
David
