Making a Woodruff key
Home › Forums › General Questions › Making a Woodruff key
  • #134917
    Danny M2Z
      @dannym2z
      G'day.
      I have been asked to make a Woodruff key for an electric motor driving an aluminium gear (mates rates, payment in stubbies).
      So what is the best way to approach such a simple job?
      I thought of using plasticene to get the diameter, turning and parting off a disc and then milling it to fit. Might paint it dayglo to help find this one. Any pointers?
      Regards from the land of the kangaroo
      * Danny M *
      #22938
      Danny M2Z
        @dannym2z
        #134919
        Tony Pratt 1
          @tonypratt1
          Turn to the reqd diameter, mill the flat & then part off to get the key, well that in theory should be the best waysmiley
          Tony
          #134920
          Gordon W
            @gordonw
            I've made a couple of keys in the past. Just saw of a slice from a high-tensile bolt of the right diameter ,file to thickness and cut of to correct hight. Keys are made to standards, see mHand book.
            #134925
              Plent on e-bay and they are not expemsive and likely to be a better fit and the correct hardness.
              J
              #134938
              jonathan heppel
                @jonathanheppel43280
                A woodruff in an aluminium pulley might as well be mild steel- no point in using anything fancier. They shouldn't really be used for transmitting much torque anyway. The keyways are usually cut quite closely to nominal size. so I've parted off a disc a thou or so over, fitted with a file etc, then milled or more often sawn and filed to fit the pulley,
                If a close fit isn't necessary, eg if you're loctiting it, just aim for nominal size and it'll be fine,
