Posted by John Shepherd on 26/09/2014 16:52:00:
If we are considering low voltage (12v) LED arrays, then we have a choice when selecting a suitable and safe power source that is up to the job. The problem of interference and safety becomes more of an issue when we try to do things 'on the cheap'.
It is doubtful if we can have much influence on preventing people from buying rubbish but if we do it right, there is no reason not to take advantage of LEDs in the home and in the workshop when there use is appropriate.
John,
That's an excellent summary of the situation as I see it.
I do have some LED "household lightbulb" replacements [from IKEA and from B&Q], all of which are performing admirably, so far.
However: My main interest in LEDs is for Microscope Illumination and I have a very strong preference for battery powered devices in that situation.
I have done some preliminary testing on a 20W LED, with a view to using one or more of them as a Fibre Optic Illuminator … Given that the light output from LEDs is essentially cold; it's surprising how much heat is generated from the back of the device [effectively, of course, it's the vast majority of the input power]. This thing will need a serious heatsink! … This is also true of the GU10 lamps that we have been discussing, and I suspect that the heat build-up within typical domestic lamp-holders may be greater than users expect. Add that to "economy" construction, and the prognosis is not good.
I have a small "non-contact" thermometer on order, so should be able to do some quick'n'dirty experiments.
