Just joined having acquired a mini lathe
Home › Forums › Introduce Yourself – New members start here! › Just joined having acquired a mini lathe
  • #493037
    stan smythe
      @stansmythe78809
      I am an enthusiastic DIYer and just acquired this lathe, it will be a few weeks before I get to use it as it requires a good bit of restoration.
      I don`t have any `trade qualifications` but enjoy most anything thats mechanical.
      I live in Scotland and retired.
      #40898
      stan smythe
        @stansmythe78809
        Elliot Unimat
        #493053
        David George 1
          @davidgeorge1
          Hi Stan welcome to the forum. What sort of parts do you make.
          David
          #493065
          Steviegtr
            @steviegtr
            When you start to use it ,there will probably be many questions you have. Ask away on here . Lots of knowledge.
            By the way welcome.
            Steve.
            #493068
            stan smythe
              @stansmythe78809
              David as yet not making anything, just got the lathe so going to be a learning curve.
              Steve, thanks and yes will be lots of questions in the coming months I am sure.
              #493072
              Andy Carlson
                @andycarlson18141
                Welcome to the forum. Looks like you have a decent set of accessories there but you need to do some rust removal.
                My preferred weapon is citric acid which can be bought as a little box of powder from the chemists. Mix it in some hot water and leave the parts to soak, maybe 30 mins for light rust, a lot longer for heavy rust, then attack it a mild scourer (e.g. a green pan scrubbing pad) or maybe a brass wire brush (the kind sold for use on suede).
                Others may prefer products like Evaporust.
                Your motor looks non original – nothing wrong with that though provided it works OK and may be more suited to continuous use than the original.
                #493073
                stan smythe
                  @stansmythe78809
                  Posted by Andy Carlson on 27/08/2020 23:47:32:
                  The accessories will be secondary to getting the lathe back to working, then I can work out what the rest is for.
                  I agree the motor is not original especially the way it has been wired up.
                  #494233
                    Welcome to the forum, Stan,
