Hydraulic Oil Supplier
Home › Forums › Beginners questions › Hydraulic Oil Supplier
Viewing 15 posts - 1 through 15 (of 15 total)
  • #5166
    ChrisH
      @chrish
      #54959
      ChrisH
        @chrish
        A recent letter in either ME or MEW – I forget which – recommended a lightweight hydraulic oil for general lubrication of machines in the workshop.
        The oils suggested were Shell Tellus R37, BP HLP 32 and Mobile DTE.
        Does anyone know where one can buy such oils in small quantities, like 1 or 5 litres at a time?  The only quantities I have seen on the internet are for 20 litre drums at around 50 GBP a time – more money than I want to spend for far more oil than I need.
        Is there a reasonable solution?
        #54962
        Clive Foster
          @clivefoster55965
          Castrol Hyspin AWS 32 is another oil with essentially the same characteristics and viscosity.  RS components sell it mail order in 5 litre bottles at an acceptable price.  I use Hyspin for the purposes mentioned  along with Castrol Magna BD68 which is a good slide-way, gear and heavy bearing oil which RS also sell.  Both are good oil can oils.  BD68 is excellent on hinges where it hangs on for ages, well worth the extra trouble of working it in.
          #54963
          Clive Foster
            @clivefoster55965
            #54964
            chris stephens
              @chrisstephens63393
              One variety of  Hydraulic oil can be bought from your local car accessory store, just look for something that says “car jack oil” or similar. Might not be what you want but might be worth a look, if you only want to buy a litre bottle.
              chriStephens
              #54967
                Warco do head oil which is a hydraulic oil in small amounts.
                This has also been covered before in this post
                Jason
                Edited By JasonB on 01/09/2010 07:35:23
                #55115
                ChrisH
                  @chrish
                  Thanks for the replies – sorry for the delay, have been away.
                  Have completely forgotten about RS components, that is noted now!
                  Plan to go to the Warco open days so may get a can of head oil there.
                  #55116
                  John Stevenson 1
                    @johnstevenson1
                    Automatic transmission oil does the same job as most of the hydraulic oils and it’s usually available in smaller quantities from motor stores.
                    John S.
                    #55120
                    V8Eng
                      @v8eng
                      Have you looked in Halfords?
                      Our big local store seems to stock specialist oils, but in the tools area rather than main (engine) oils section.
                      Edited By V8Eng on 04/09/2010 22:31:48
                      #55622
                      A Smith
                        @asmith78105
                        Buck and Hickman list & stock Hyspin 32 and Magna BD 68.  They sold me 5 Ltrs of Hyspin 32 for £13 (£12 something),  which was the same that their catalogue price without VAT.  If you have branch nearby, it’s worth going in and asking.
                        #55632
                        DMB
                          @dmb
                          I have seen the following recommended as a slideway oil concoction;
                               1 part STP or Wynn`s oil treatment (its very sticky to stay put.)
                               1 part Molybdenum DiSulphide, a graphite oil, tradename, Molyslip.This was recommended to fill any minute spaces with balls of graphite to lubricate.
                               20 (?) parts EP90, Extreme Pressure oil
                          Shake vigourously every time b4 use.
                          I use it on Myford bed  and graphite grease on leadscrews, Lathe & Mill. I use Myfords oil for the  bearings on MLS-7, Mill and Fobco Drill. I keep Myford oil in a Rheilang pump can for two reasons; it doesnt waste oil like other makes of pump cans so is economical with expensive oil and as it doesnt spill everywhere, I dont get oiled as well!
                          Gordon W
                            @gordonw
                            I don’t know where you live, but I’ll repeat; tractor and farm shops sell all sorts of oils ,including, of course, hydraulic oil, and are usually much cheaper than other outlets. I use universal tractor oil, for almost everything, some kind farmer ( there’s an oxymoron) gave me about 10 galls. This was used for everything on the machine, engine, g/box, brakes,etc.. If its good enough for a £100,000 m/c it’s good enough for me
                            #55654
                            Gordon A
                              @gordona
                              Don’t know where you are situated, but Hallett oils in Wolverhampton (01902 745800) are very helpful. (no connection except as satisfied customer)
                              #55871
                              Ian Welford
                                @ianwelford58739
                                I recommend. Smith & Allen of Darlington. Very helpful and sell in 5l cans
                                 I use a hydraulic oil with high pressure additives on my Alexander mill. Works fine!
                                S & A phone number is 01325 462228.
                                #55877
                                ady
                                  @ady
                                  As mentioned, tractor and farm places.
                                  Boat and shipping places also carry a lot of oil types and a case of decent beer could get you a 5-10 litre canful from an engineer.
                                  It’s like with scrounging scrap from engineering places.(who might have oils too btw)
                                  All you have to do is ask nicely…and hope you get a sympathetic ear.
                                  Edited By ady on 18/09/2010 21:59:29
