How to identify solder on an old boiler
Home › Forums › Beginners questions › How to identify solder on an old boiler
  • #11217
    Russell Furzer
      @russellfurzer50760
      second hand boiler assessment
      #599737
      Russell Furzer
        @russellfurzer50760
        I have found an apparently nicely constructed copper boiler in a junk store. It looks home-made and is along the general lines of a ST 501.
        I am 99% sure that the solder is proper silver brazing, but wonder if there is a test that i can apply?
        I understand the sequence of pressure testing and will do a cold hydrostatic test before talking to our local AMEB inspector
        If the solder is not correct (or if it fails the hydro test), i wont bother him and will scrap it
        #599741
        Speedy Builder5
          @speedybuilder5
          Lead solder is soft and you could scrape a little off with a pen knife. Silver solder is harder, if you cleaned the joint with some wire wool, it would look a very pale gold colour.
          The Stuart ST 501 is a low pressure boiler and even lead solder would be acceptable although if starting afresh lead free these days..
          follow this link if in doubt:- Mamod Boiler
          Bob
