Help with surface plates in Derby
Home › Forums › Workshop Tools and Tooling › Help with surface plates in Derby
Viewing 25 posts - 1 through 25 (of 33 total)
  • #555987
    Pippin
      @phillspowart84010
      Anyone near Derby able to help me with a couple of surface surface plates? Both suffered surface rust and pitting, I'd like to surface grind out the damage then get it blued and scraped in against a decent master. Be handy to get a few pointers on scraping too, only so much you can get off youtube. One is 15 x 18", other is 8 x 12"
      #20396
      Pippin
        @phillspowart84010
        #555997
        Mike Poole
          @mikepoole82104
          A good quality surface grind will probably be flat enough for most practical purposes. A scraped finish will look nicer, be flatter and a better surface for bases to glide over but unless you fancy the challenge it could save a lot of work to not go further than the grind. The surface of my plate is not scraped but doesn’t look surface ground either, it seems devoid of any type of machining marks.
          #555998
          Brian H
            @brianh50089
            I know that a scraped finish is traditional but is it really necessary for what you are doing?
            Many years ago I scrounged a surface plate that had gotten into the hands of sheet metal workers (never a good idea).
            I took it to a small local company that has a Snow grinder. These are large grinders with segmented stones and grind horizonataly. so is perfect for this type of work and they are large so will do the work in one pass, meaning that it is a lot cheaper that normal surface grinding.
            You can scrape them in if you have a master table to work from, or use the traditional method with 3 plates but I've never found it necessary as I'm not chasing tenths.
            #556000
            Pippin
              @phillspowart84010
              I want to try and get my machines and tooling into good order, so I figure the best way is to start with a master surface I can rely on. Then I can be sure that any problems are my own ineptitude. I'm also finding that the current variations in finish are making it hard to tell if I'm applying the blue evenly.
              #556003
              Baz
                @baz89810
                Rather than grind the surface how about a planed finish. I find that the height gauge tends to stick on ground plates whereas I don’t get anywhere near as much sticking on the planed plate.
                #556004
                Anonymous
                  My 36"x24" Windley Grade B (workshop) surface plate doesn't look like it's been ground or scraped:
                  There are a series of horizontal lines about 5/16" apart, almost as if it's been planed. Unless you're rebuilding machine tools part by part I'm not sure how a surface plate helps with machine tool setup.
                  #556012
                  Baz
                    @baz89810
                    Andrew that is a planed finish, I have a Windley workshop grade bought back in the early seventies, not as big as yours, only 24 x 18 but big enough for a set of loco frames!
                    #556018
                    Pippin
                      @phillspowart84010
                      "Unless you're rebuilding machine tools part by part"
                      That is the ultimate aim, yes
                      #556021
                      Pete.
                        @pete-2
                        Why not get a granite surface plate, you can buy a brand new 00 laboratory grade granite plate for under 300 quid.
                        #556027
                        Howard Lewis
                          @howardlewis46836
                          There is a sequence for lapping a surface plate absolutely flat, but involves lapping two others together and using the result to lap the final one.
                          Very much an iterative process, obtaining an improvement at every stage.
                          So neither quick nor easy.!
                          Full marks for aiming for the best that you can get with the facilities available. Go for it.
                          A machine tool needs to more accurate / precise than the work that it is required to produce. Tolerances and clearances, may be minute, but they build up into quite sizeable figures. 0.0005 on a shaft and 0.0005 on the bush in which it runs will give 0.001 clearance. Do that on the location of the bush in the Headstock, and on the Headstock / Bed locations and things start to look less than precise!
                          #556029
                          duncan webster 1
                            @duncanwebster1
                            Best of luck finding a planer nowadays, and if I had £300 spare I wouldn't blow it on a surface plate
                            #556030
                            Pippin
                              @phillspowart84010
                              Been looking out for granite plates, but not got anything yet. Once my big plate is flat, I figure I'm well away, it's just getting to that stage.
                              #556032
                              Pete.
                                @pete-2
                                Where have you been looking? a simple Google search, the first few results Cutwel, in their surface plates, 630×400 00 grade £262 in stock, I believe delivery is included.
                                Surprisingly cheap imo
                                Edited By Pete. on 27/07/2021 18:40:54
                                #556035
                                Pippin
                                  @phillspowart84010
                                  They come up on bankruptcy auctions sometimes. Right now I've not got room for one, once new workshop is built I'll get one. For now, I just want a good plate to work off. Didn't really intend buying a big cast iron one, but it was found in a junk shop for a tenner!
                                  #556038
                                  Pete.
                                    @pete-2
                                    I'd be interested to know how much it will cost you to have an 18" surface plate surface ground then scraped in, if you find out will you report back please.
                                    #556044
                                    Pete Rimmer
                                      @peterimmer30576
                                      Scraping in a 18" plate is a lot fo work it's huge surface area. Granite plates by comparison are quick to lap in and reportedly wear more slowly. Certainly they can suffer clumsy handling without taking damage more than an iron plate can.
                                      #556045
                                      Dave S
                                        @daves59043
                                        Eley metrology can probably recondition your plates, but I bet it is more cost effective to buy a new granite one.
                                        My 4’x2’6” table has a planed finish. It’s flat (for some values of flatness – workshop grade and well out of certification. .
                                        It makes an excellent stand for the 18” granite I actually use…
                                        Pete Rimmer
                                          @peterimmer30576
                                          I recondition surface plates from time to time I tink I have seven in my workshop right now. Small iron plates I scrape, granite plates I lap with diamonds. Invariably they are out of certification, some by many years and I can tell you this – I never yet saw a used plate that wasn't out of specification for the last ticket that was on it and only one that came close.
                                          Remember this when buying any used plate – you absolutely cannot rely on the 'grade' sticker and should completely disregard it as part of any selling spiel. Grade A, grade B it doesn't matter – they almost all need re-working.
                                          #556074
                                          old mart
                                            @oldmart
                                            You could try lapping them together as they are nearly the same size, using fine compound and light oil. It would be a help if you could post photo's of them.
                                            #556108
                                            Bo’sun
                                              @bosun58570
                                              Posted by Howard Lewis on 27/07/2021 18:21:59:
                                              If I remember correctly, I think the procedure might have been down to Mr Whitworth,
                                              #556112
                                                Posted by Bo'sun on 28/07/2021 07:59:24:
                                                To quote from a post I made in 2013:
                                                This may be the most important Engineering book you ever read.
                                                It discusses the very foundation of Precision Engineering.
                                                … It's short, but very sweet.
                                                Text commencing on page 5 describes the process:
                                                “Before entering upon the subject of measurement we propose to examine the method of preparing plane metallic surfaces in the manner made known by Sir J. Whitworth at the Glasgow meeting. …”
                                                Edited By Michael Gilligan on 28/07/2021 08:50:14
                                                #556113
                                                Martin Kyte
                                                  @martinkyte99762
                                                  I know there is a desire to see nice shiny surfaces but I wonder how unserviceable your surface plates actually are. Have a go at removing the corrosion chemically (Arc Euro do stuff for this) and then check one plate against the other. Once they are cleaned up I would be surprised if they are in any way unfit for service.
                                                  Incidentally does anyone use a wax on their surface plates to reduce friction and protect from corrosion?
                                                  regards Martin
                                                  #556753
                                                  Pippin
                                                    @phillspowart84010
                                                    Been away for a few days, thankyou for the replies.
                                                    Ultimately, I'm hoping to learn scraping so I can renovate machine tools, hence the desire for high accuracy. The plates I have are just what has fallen into my lap over the years. The surface rust and finish on both is very varied, which makes getting an even coverage of blue dye much harder-and I don't have the greatest eye for it to start with. Not trusting them fully is a massive hindrance. I plan getting a proper granite table eventually, but I need to build a home for it first, currently said home is a muddy hole in my garden and piles of bricks looted out of skips.
                                                    This was very much an "on the off-chance post"-I'd feel pretty daft if it turned out a master machine rebuilder lived 5 minutes away AFTER I'd bludgeoned my way through learning it on my own.
                                                    #556754
                                                      Don't let me put you off Phil, but it takes a long time to remove metal by scraping as needed to restore a badly worn machine. For example, lathe beds tend to wear badly close to the chuck where the saddle spends most of its time make it necessary to remove a lot of unworn metal to restore flatness. Unlikely to pay off unless scraping is to be your main hobby! There's also an alternative technique for putting worn surfaces back with goo,
                                                      Scraping as a way of producing an original flat surface is rarely done today. Instead laboratory flat surfaces are produced by grinding, or perhaps a plane. The machines are laser guided and capable of producing highly accurate surfaces with minimal labour. Surface plates, starting at about £60 are cheaper than the tables needed to support them, and I feel there's not much point in a home workshop going the full Monty on a plate unless the same effort is put into supporting it correctly! Home workshops are full of dinged, out of tolerance, bent surface plates, well out of tolerance by professional standards but good enough for ordinary use. Float glass plate was once recommended as a cheap substitute.
                                                      Scraping has two main purposes today, one of them dishonest! Scraping being associated with quality, scrape marks are often added to create the illusion a piece of equipment is better than it actually is. (Same was done in the past,) More usefully, scraping is often added to provide a key to hold oil and improve lubrication. Neither of these two forms of scraping improve flatness.
                                                      Where scraping is useful for repair work is on worn plain bearings, especially if they've suffered a lube failure. Plenty of machines have roller bearings, which are just replaced.
                                                      There's always a balance between getting on with the job by flashing cash and saving money by DIY. Though I see the attraction I've decided scraping isn't worth my time. Would a renovator comment please; how much scraping is done during a typical rebuild? I get the impression time-consuming bulk flattening is usually outsourced to a professional grinding company, so the renovator can concentrate on the the machine's other needs. I may be wrong!
