Posted by Neil Mccarthy 1 on 04/09/2019 07:49:55:
Thank you all I am even more confused now. If you had £700 to spend on a lathe and accessories what would be the best deal to get please. I need something that I can bore and tap as Well and make parts for my rifle that are now obsolete
thank you
Neil, perhaps in the mass of posts you missed my advice which is for what you want to do there isn't much difference between any of the various machines in the Mini-lathe class. They will all turn brass and steel. Any of them will do the job.
I dithered for ages before buying a mini-lathe. It's very easy to get confused by details that probably don't matter much! As there isn't really an obvious leader or an obvious crock you won't go far wrong whatever you buy. I achieved very little by fretting and my time would have been better spent learning to use a lathe rather than confusing myself looking at sales literature.
Today I personally would favour a brushless machine like ArcEuro's Seig but it's a close run thing. There's nothing wrong with the Amadeal Bundle you identified: for a reasonable price you get all the bits needed to cut metal out-of-the box. It's an attractive starting package. I personally have no experience of Amadeal as a supplier but – if it helps – I don't recall any complaints about them on the forum either. If Amadeal take your fancy, go for it.
The one thing I'd advise against is buying very cheap or from an unknown ebay seller or direct from China. It's because this multiplies the risk of getting a poor example (they exist) coupled with an ineffective warranty. Buying from an established British vendor de-risks what happens if the lathe arrives damaged or is unmanageably crude.
By the by you will have spend some time practising to get the best out of the lathe. For example, you might have bad trouble turning stainless steel. It's not because the lathes are inferior but because many stainless steels make life difficult by work-hardening severely during cutting. The cure is to change the steel, not the lathe.
I recommend getting a good book too. Sparey's 'The Amateur Lathe' is the classic, but omits modern ideas like carbide inserts because they weren't available when the book was written. More up-to-date and aimed squarely at the Mini-lathe is Neil Wyatt's 'The Mini-lathe' as sold by Camden. Camden are worth exploring for other technical titles.
Don't be afraid to ask questions on the forum either. It's remarkably good at answers!
