Hello from South Wales
  • #480357
    Andy welburn
      @andywelburn28777
      Hello All. Andy here, based in South Wales not a million miles away from Swansea. I have an old Myford ML7 and an EMCO F1 mill. I'm currently amusing myself machining "Turners Cubes" from wood and trying to learn some machining and CAD/CAM skills.
      Eventually I'd like to design and build a 250cc V twin motorcycle engine using a lot of old Honda CG125 parts, and then put it into a bike.
      I'm considering upgrading the EMCO F1 to something with a bit more travel but not looking to spend too much.
      Andy
      #40846
      Andy welburn
        @andywelburn28777
        #480427
        Brian Wood
          @brianwood45127
          Welcome to the Forum Andy.
          Perhaps you should graduate to machining metal on your machines, wood dust is a very poor lubricant and might actually make your ML7 even older with it's effect on the white metal bearings. I think it would pay you dividends to clean things thoroughly before you make that change.
          Your project sounds ambitious, is this to make a road use bike? There are plenty of bike enthusiasts on the Forum who will I'm sure be happy to pass on their experience.
          Regards Brian
          #480446
            Hi Andy,
            Welcome to the forum, I originally come from Barry myself
            colin brannigan
              @colinbrannigan54160
              Hello Andy, and welcome, I am also near Swansea in Southgate on the Gower and I also mess with motorcycles but old British stuff.
              Colin
              #480612
              Andy welburn
                @andywelburn28777
                Thanks for the welcomes chaps.
                Brian – all my wood machining is done on the mill rather than the lathe and I ALWAYS have the vacuum cleaner on extracting dust as it's made. In fact I recently bought a new vacuum as my old "VAX" was starting to emit burning smells. I wouldn't say the new vacuum is good but so far I've had to retrieve a 13mm spanner and a big felt tip pen out of the drum, as well as plenty of sawdust and swarf.
                Neil – I nearly bought a house in Barry but it fell through. Never mind.
                Colin – I have a modern Triumph and an Indian Royal Enfield at the moment, as well as a CG125 and a Yamaha TY250. For some strange reason though I've developed a hankering for a British 250. I'm thinking along the lines of a Crusader, C15/Starfire or a Panther.
                As for my fantasy (presently) engine project, I've got a couple of potential donor engines but I need to do a lot of sorting out and tidying up in the garage (and another bike build project) before I can make a proper start on it. I'll get there eventually! Lots of learning to do on the way.
                Andy
                #481069
                stevetee
                  @stevetee
                  Hi there, i'm further down the coast ger Abergwaun. Have you read about the Carberry Vee twin. The bloke developed a vee twin based in the Enfied India 500cc single engine, which could be of interest to you as a process.
