hallam engine
hallam engine
Home › Forums › Beginners questions › hallam engine
Viewing 15 posts - 26 through 40 (of 40 total)
  • #142202
    V8Eng
      @v8eng
      The more I see of this the more it seems like an owner has modded it to suit their own application.
      Certainly very interesting!
      Maybe it reminds me of my childhood, watching men launch rather large IC powered flimsy looking (free flight I think) planes at Epsom Downs, then riding their pedal cycles trying to keep up as they flew off into the distance.
      Edited By V8Eng on 30/01/2014 19:35:56
      #142203
      thomas oliver 2
        @thomasoliver2
        This engine is definitely a Hallam Nipper 1942 as shown by the angled webs and the split crankcase. The 10cc models had a one piece crankcase as shown in Mike Clanfords book. Hallams also made a 13cc model and a 5cc. twin. Their drawings were rubbish and inaccurate and the castings poor.
        #142217
        p j riordan
          @pjriordan89154
          hi again lads
          v8 you could be right as the man who had it was in to stuart turner`s and rail stock ,thomas any idea if it is 10cc or 13 cc as i dont have a clue ,
          #142229
          p j riordan
            @pjriordan89154
            i have also got model engineer in book form from july 7 1949 to dec 29 1949 some great engines in it if there are any you are looking for please just let me know as i will take pics and send them on
            yours
            p.j.
            #142240
            p j riordan
              @pjriordan89154
              #142241
              p j riordan
                @pjriordan89154
                its called a super 9
                "There was something strange here that needed further investigation, but in the meantime it was back to the ‘mystery motor’. What was clear was that it was not a large hydro motor, and from the various features that it definitely was a Hallam, but not one in any of the usual reference books. It was not a ‘Hallam 10’ as it had conventional mounting lugs. It looked similar to a Series III Nipper in many respects, but was too big, as a vernier dropped down the plug hole confirmed. The only clue was a note that the Nipper Series III had been produced in a larger version called the Super Nine. Here we were stuck until the late Mike Beech came to the rescue. Mike was incredibly knowledgeable about the products of the company from Poole and recognised the motor as a Super Nine, which was only produced for about a year around 1947, and only available as a factory produced unit. This was somewhat unusual, as much of Hallam’s production was castings and kits for home building"
                Found this onthewire site dont know if this is one of them
                yours
                p.j.
                Edited By JasonB on 31/01/2014 07:21:54
                #142245
                  Note for our ever-helpful Moderators
                  [at least on my iPad] … P.J.'s last post has the "Text Under Adverts Syndrome" … which I haven't seen for a while.
                  Could someone please correct this?
                    Is that Better? Quote had been pasted in some sort of text box.
                    J
                    #142257
                    p j riordan
                      @pjriordan89154
                      hi
                      thank you both for sorting out that text thing . it was the only way i could get that quote on for you all to see
                      yours
                      p.j.
                      #142351
                      p j riordan
                        @pjriordan89154
                        hi again
                        dont know if anyone can confirm whether this is a super 9 ?
                        yours
                        p.j.
                        #142395
                        p j riordan
                          @pjriordan89154
                          hi dose anyone know anything about the super 9 ?
                          #142636
                          p j riordan
                            @pjriordan89154
                            hi again
                            seems like everyone has left this item not sure whats going on
                            yours
                            p.j.
                            #142807
                            thomas oliver 2
                              @thomasoliver2
                              The Nipper was 5.4cc. The factory produced the carb intake cast in with the tank top. Your tank/carb is not to the factories usual design, and probably made to the makers own design. Clanfords book says the Super nine was an enlarged Nipper Series 111 which did not have the split crankcase cylinder layout. They made a 7,5cc with external holding down cylinder studs and a the 13cc with a similar arrangement but it and the 7.5cc had a plain cylinder head top with no radial fins,
                              My 10cc Hallam measures 1.625ins across the fins, and my 5.6cc Mechanair ( about the same size as a Nipper) is only 1.25ins across the fins. The later Nippers were a one piece casting. The 13cc had a had two split castings.
                              #142818
                              Ramon Wilson
                                @ramonwilson3
                                Hullo Thomas – Just thought you might like to know that with all this latest on 'Hallams' I got your drawing out only yesterday and have begun to make a set of drawings to have a go at making one from scratch as originally intended. The crankcase is drawn and I think with a couple of small allowances I should be able to machine it from solid. It'll be a while as yet before machining as there are several other matters pending but I'll keep you posted.
                                Regards – Ramon
                                #142837
                                p j riordan
                                  @pjriordan89154
                                  hi thomas
                                  if you have a look at the car pic above ,i think the carb is the same as my one as to the fins i will measure them and get back as soon as poss .
                                  yours
                                  p.j.
