Ground flat stock supplier ?
Home › Forums › General Questions › Ground flat stock supplier ?
  • #125640
    ken king, King Design
      @kenkingkingdesign
      Can anyone please suggest a source of accurate 1/8" steel plate (not 3mm), either G.F.S. (expensive) or some other description which fits the bill. I'm looking for enough to make four bolting plates, each about 21/2" x 31/2" . Slightly thicker plate capable of being surface ground to thickness would also be acceptable.
      #22739
        @kenkingkingdesign
        I need accurate 1/8″ steel plate
        #125642
        Alan Reed 1
          @alanreed1
          #125643
            You won't easily find 1/8" plate but Bright Mild steel flat bar is still readily available in imperial so you could use 2 1/2" x 1/8" this is likely to be withing a thou or so if thats good enough.
            Failing that most of the ME suppliers will have gauge plate (GFS) M-machine have both
            #125667
              @kenkingkingdesign
              Thanks for responses. M-machine now live in my Bookmarks bar.
              #125938
              mike mcdermid
                @mikemcdermid41977
                Ken M machines prices are quite ..er shall i put it politely expensive sheffield gauge plate sell entire 18 inch lengths for the same price as the 9 inches m machine are asking
                #125948
                David Colwill
                  @davidcolwill19261
                  I use RS, as they are cheaper than cromwell and have it in stock (at head office).
                  #125972
                    @kenkingkingdesign
                    Thanks for further tips guys. All good helpful stuff and appreciated,
                    Ken.
                    #125974
                    David Littlewood
                      @davidlittlewood51847
                      Posted by mike mcdermid on 01/08/2013 23:01:47:
                      Indeed – and I would be quite uneasy about buying from anyone who seems to think that 1/2 sq ft is the same as 6×6"!
                      David
