Grinding wheel ‘washers’
Home › Forums › Beginners questions › Grinding wheel ‘washers’
Viewing 15 posts - 1 through 15 (of 15 total)
  • #9887
    Cornish Jack
      @cornishjack
      #432291
      Cornish Jack
        @cornishjack
        I have a Tiplap grinder with two original Boremaster wheels. They aren't really suitable for general grinding, so I am fitting a carborundum cup wheel . I have made a new mounting adaptor but I am unsure about the type of 'washer' to fit on either side. I have cut our a couple from the cardboard of a tool package. Is this appropriate or should they be made from something less 'agricultural?
        TIA
        rgds
        Bill
        #432292
        John Reese
          @johnreese12848
          I cut my "blotters" from the cardboard back of a writing tablet.
          #432300
          old mart
            @oldmart
            The cardboard from a cereal packet or slightly thicker would be fine, you could cut a stock and change them every time a wheel is changed. As you are obviously aware of the importance of the soft interface, there is nothing more to say.
            #432306
            Cornish Jack
              @cornishjack
              John and Old Mart – thank you. Both your suggestions are much less 'spongy than the card I have – no writing tablet and no cereal packet . I have a nagging feeling that what I have produced is not ideal! I shall have to search further.
              rgds
              Bill
              #432316
              Grindstone Cowboy
                @grindstonecowboy
                If yours are a bit thin, just double them up. I have also seen vinyl flooring used – the spongy sort – but not entirely convinced this is 'right'.
                #432319
                Baz
                  @baz89810
                  Use your favourite cereal packet, makes excellent washers, not convinced that vinyl flooring is suitable though.
                  #432325
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi Bill, or just get some Blotting Paper
                    Regards Nick.
                    P.S. there are others available, the link is just an example.
                    Edited By Nicholas Farr on 07/10/2019 23:13:45
                    #432329
                    ega
                      @ega
                      Unless your flanges are rustproof I suggest you make the blotters from something that won't harbour moisture.
                      #432338
                      Joseph Noci 1
                        @josephnoci1
                        Thin Gasket sheet from your local motor-spares supply works very well – I use around 0.6mm material. In my town, around £3 for a half square meter. Use the rest on your model engines..
                        Joe
                        #432342
                        mechman48
                          @mechman48
                          Any of the above are deemed suitable; they are to allow for slight imperfections on the outer faces of the wheels & equalise the loading of the metal discs. As with all grinding wheels; apart from resin bonded type give them a 'ring test' with any non metallic tool, screwdriver handle, small hammer shaft etc, if it rings your good to go, if a dull sound, bin it, as it will have a crack/damage somewhere.
                          George.
                          #432343
                          Martin Kyte
                            @martinkyte99762
                            As I understand it what you are trying to acheive by interposing 'soft pads' between the clamp washer and nut and the wheel is the avoidance of local stress on the wheel caused by it's rough surface. basically something to conform to the surface and fill all the gaps. So still enough to hold firmly buut soft enough to give a little to spread the load.
                            Pretty much all the materials that have been suggested above fit the bill.
                            regards Martin
                            #432346
                            Cornish Jack
                              @cornishjack
                              Thank you all again.
                              From all the advice given, I'm concerned about the compressiblity of the cardboard I had intended to use. As I said, it's just a standard piece of a cardboard box and doesn't have the less compressible qualities of e.g. gasket material – maybe I'm over-worrying!
                              rgds
                              Bill
                              #432354
                                The elfin folk have very kindly provided this, free to download: **LINK**
                                https://www.hse.gov.uk/pUbns/priced/hsg17.pdf
                                It’s an excellent little document, and p19 is particularly relevant.
                                Pete Rimmer
                                  @peterimmer30576
                                  Posted by Cornish Jack on 08/10/2019 09:12:32:
                                  rgds
                                  Bill
                                  I think you are Bill. All of the wheels I have in my workshop have simple paper blotters. Not much give in them at all.
