great youtub
great youtub
Home › Forums › General Questions › great youtub
Viewing 21 posts - 1 through 21 (of 21 total)
  • #26078
    Brett Hurt
      @bretthurt41827
      great work look at it
      #361156
      Brett Hurt
        @bretthurt41827
        this guy is great https://www.youtube.com/watch?v=IR2p9ceg1bw
        Edited By JasonB on 08/07/2018 07:01:09
        #361162
        I.M. OUTAHERE
          @i-m-outahere
          Thanks Brett !
          A very interesting video and a very useful set of clamps !
          I like his mill !
          #361164
            Only odd thing to me was that the jaws are not keyed on in some way as all the downward clamping force is taken by a couple of small cross head screws?
            Nice horizontal borer and I like the packing blocks he was using with their tapped holes so you can get the clamp stud right up close to the work
            #361165
            Raymond Anderson
              @raymondanderson34407
              Very nice work, Solid looking clamps.yes
              #361166
                Beautifully 'sculpted' … and much larger than I imagined, from the opening shots.
                Very impressive.
                mick70
                  @mick70
                  love them.
                  but question about it from someone who knows little about milling having only done very basic bits on one.
                  i assume he used cutter to start bolt hole then finished with drill bit as cutter less likely to wander giving better accuracy?
                  #361169
                    Posted by mick70 on 08/07/2018 09:23:29:
                    … i assume he used cutter to start bolt hole then finished with drill bit as cutter less likely to wander giving better accuracy?
                    Correct, Mick yes
                    The side loads on the drill would be appalling, otherwise.
                    richardandtracy
                      @richardandtracy
                      Wouldn't mind his mill.
                      The idea is entirely scalable, and is a good one.
                      Jason, the jaws are held on with two screws that look to be one size smaller than the main clamp. The vertical clamp load, neglecting friction, could then shear the two jaw screws. As the area of the jaw screws is about 20% greater than the clamp screw, it's theoretically possible to shear the screws when clamping down. In practice, because friction exists, this won't be likely. I agree a key would be useful, I wouldn't argue against it – based purely on all the un-necessary brochure machining already being put on the clamps, so adding a key would be a negligible increase in machining time. But the key is not strictly needed.
                      Richard.
                      #361172
                      Rik Shaw
                        @rikshaw
                        I would love a set of clamps like this albeit a bit smaller. The question is, can I afford the time it would take to make them while working at my normally relaxed "speed"? sad
                        Rik
                        #361189
                        Ian McVickers
                          @ianmcvickers56553
                          Nice bit of workmanship there. When I saw the first picture I thought how did he manage the large radius? Good to see the techniques used and the finished job. Now all I need is an enormous bed mill that cuts steel like butter…..
                          #361191
                          Mick B1
                            @mickb1
                            Posted by Rik Shaw on 08/07/2018 09:49:51:
                            Rik
                            I think there's a few of caught on the horns of that dilemma. laugh
                            Of course, if all you really gotta do is scrawl a few chalk lines on a block, chuck it in the mill and turn on, I dunno what all this engineering mystique is about… wink 2
                            #361193
                            Vic
                              @vic
                              Good link Brett, thanks. I would have liked to see what the mill he used looked liked though, seems to be a monster! Also, the finish straight off the machine didn’t look particularly good on those clamps but then in the final shots they looked great? The Vee blocks from rail track video is also pretty good.
                              #361212
                              Clive Hartland
                                @clivehartland94829
                                I saw a tape measure and one time a vernier but the chalk intrigued me, All this careful marking out seems a waste of time. He did use blocking in the table grooves and that machine was quite powerful it seems.
                                #361214
                                  I think the chalk was for the camera, I one shot you can see he has blued a line and scribed onto that.
                                  #361217
                                    You can see a bit more of his borer in this video. Or if you have 25,000 Euros to spare this is the one for you!
                                    #361219
                                    mick70
                                      @mick70
                                      Posted by Michael Gilligan on 08/07/2018 09:37:21:
                                      Correct, Mick yes
                                      cheers for that.
                                      a good day as learnt something new.
                                      #361221
                                        Posted by JasonB on 08/07/2018 13:57:35:
                                        Fabulous machine, in a great workspace
                                        < drool >
                                        But I'm a little surprised that he hasn't discovered the merits of a decent ratchet & flank-drive sockets.
                                        Ian Skeldon 2
                                          @ianskeldon2
                                          I was even more surprised to see him brush swarf away with his bare hands, is this man a god?
                                          Nice clamps though, although his machining skils and tooling means that he probably made them, just because he could, I'm somewhat envious.
                                          #361748
                                          mechman48
                                            @mechman48
                                            Nice clamps. He certainly knows how to use that vertical boring machine. I guess this is the same guy that made that very large vice I saw on You Tube. not a lot of activity going on in that factory, maybe he was working in his own time on a weekend maybe?
                                            George.
                                            #361760
                                            thaiguzzi
                                              @thaiguzzi
                                              Posted by Ian Skeldon 2 on 08/07/2018 16:58:56:
                                              Concur, great vid, great component finish.
