Grass cutter
Grass cutter
Home › Forums › The Tea Room › Grass cutter
  • #34887
    Dennis D
      @dennisd
      #291853
      Dennis D
        @dennisd
        Here's a use for those old engines you have at the bottom of the garden
        Bazyle
          @bazyle
          I recon two oxen is about as powerful as our old Fergie so you could just pull and old Ransomes gang mower, or just let them eat it down.
          #291858
          V8Eng
            @v8eng
            I wonder how far unguarded pieces of broken mower blade can travel, I would want to be a long distance from that thing.surprise
            #291872
            Adrian Giles
              @adriangiles39248
              Many years ago, when I first started work, I sold a hover mower to Charlie Watts. Some time later, his gardener came to us refusing to use the machine. It turned out that the blade had broken in half at the blade bolt during use! The bolt was still in place! Neither half of the blade was ever found!
              #291877
                Posted by Adrian Giles on 02/04/2017 23:11:20:
                Now that's a rock'n'roll story not many people can tell!
                Jeff Dayman
                  @jeffdayman43397
                  "I wonder how far unguarded pieces of broken mower blade can travel,"
                  Don't know the answer to that one, but I can tell you something about the force of that sort of thing. When I was about 16 I was mowing the back lot at my Grandfather and Father's garage using a rotary mower with a 3.5 HP Briggs and Stratton engine. I was 6 foot tall and about 225 lb at the time, a strapping lad and no flyweight. The blade did not break but the cast iron hub between blade and engine shaft did break. A piece of this hub about half a pound in weight flew out from under the machine and hit the ankle of my work boot. The force was enough to knock both legs out from under me and next thing I knew I was looking up and seeing grass and the mower-still running!. No real injury other than a black and blue sore ankle, but it was an eye opener about the potential danger of mowers. JD
                  #291899
                  Nick_G
                    @nick_g
                    Posted by Neil Wyatt on 02/04/2017 23:40:37:
                    I wonder how long it was before he realised the grass it cut was not the kind he was really after. winkwink
                    Nick
                    #294959
                    Steve Ambler 1
                      @steveambler1
                      Having grass with a rolling stone that's got to be rock & roll
                      Steve
