Glass filled nylon 66 granules.
Home › Forums › General Questions › Glass filled nylon 66 granules.
  • #140409
    David Clark 13
      @davidclark13
      Because of the injection moulder series in MEW I would like to get hold of some 30% glass filled black nylon 66 granules and some grey ABS granules.
      Does anyone know where I can get small quantities of these?
      I don't mind buying a bag full if not too expensive but a small amount would last a long while.
      A Google search and Ebay have drawn a blank.
      regards David
      Edited By David Clark 1 on 11/01/2014 22:44:03
      #23068
      David Clark 13
        @davidclark13
        #140411
          David,
          This looks promising.
          Keith Long
            @keithlong89920
            David
            PM sent.
            Keith
            Edited By Keith Long on 11/01/2014 23:18:59
            #140419
            Gone Away
              @goneaway
              Call one of the plastics companies who supply material to injection moulders and ask for a small quantity. GE, Borg-Warner (think they are GE anyway these days) or whoever in the UK. Play up that you are editor of MEW and that it relates to an article in the magazine.
              Any of the companies I dealt with before I retired would have been happy to oblige …. it's chicken-feed to them.
              #140429
              Jeff Dayman
                @jeffdayman43397
                http://www.sabic-ip.com/gep/Plastics/en/ProductsAndServices/ProductLine/cycolac.html
                Sabic Innovative Plastics (formerly GE Plastics) are a major manufacturer of ABS
                BASF also makes many grades of ABS
                DuPont are a major nylon manufacturer, one engineering grade GF nylon of theirs is Zytel
                Hoechst are a second major nylon manufacturer , their generic brand name for nylons is Celanese
                Not sure if these firms have distributors in UK but they probably do, they certainly do in Germany and North America.
                Just FYI – Accurate temperature control in the barrel and in the mould per manufacturer's resin data sheet / processing instructions is very important for good injection moulding in most resins, but especially for ABS and PC. It is wise to keep this in mind if making a moulding machine for home shop use.
                Sabic IP's website has an excellent section on good design practice for injection moulds and moulded parts with lots of general info applicable to home shop moulds or commercially made ones.
                JD
                #140430
                Stewart Hart
                  @stewarthart90345
                  David
                  One thing I learnt about moulding glass filled nylon 66 is that it must be very/very/very dry otherwise you get brittle fracture of the parts, (I still have the scars) so stick it in the oven on a low temp for 1/2 an hour before you use.
                  Good luck
                  Stew
                  #140439
                  David Jupp
                    @davidjupp51506
                    I used to work in the Polymers side of BP (before it was divested) – most polymer manufacturers have at least one 'small order' distributor for dealing with orders of less than a full truck load. The main sales office of the manufacturer should be able to advise who they use in the UK. – and as stated above you might even get a free sample.
                    Make sure you ask for an injection moulding grade, even then there may be several to choose from from a particular manufacturer. If you can get to speak to the Technical Support team, they can help with grade choice, and may even be authorised to arrange for samples.
                    Glass filled grades can be very hard on the processing equipment (rapid wear) – but in a hobby situation that may not be so important.
                    #140449
                    David Clark 13
                      @davidclark13
                      Hi There
                      Thank you alll.
                      regards David
                      #140450
                      martin perman 1
                        @martinperman1
                        Gentlemen,
                        Another point not mentioned is that if the granules are over heated they will give off an acid vapour, whilst installing a robot onto an IMM an operator purged the injection barrel of a machine in the same room with a different material than had been used and didnt turn the heat down after a short while the room was cleared because of runny eyes and saw throats. Its a regular job in IMM shops to also clean the building steel work of acid to stop corrosion.
                        Martin P
