Gas Valve for regulator
Home › Forums › Locomotives › Gas Valve for regulator
  • #198503
    Ron Hancock
      @ronhancock63652
      No idea but they work very well and any one that uses them sing their praises.
      The only negative is from people who have not tried one and believe you should use original design.
      I just want one to work properly and reliably witch these have proven to be so.
      Plus are the ones we make Rated for steam pressure after we make them.
      Ron
      Edited By Ron Hancock on 30/07/2015 17:26:06
      Edited By Ron Hancock on 30/07/2015 17:26:55
      #230296
      Keith Spence
        @keithspence94888
        Hi All just seen this topic.
        I have a 5inch Brittania with a ball valve regulator.
        Due to troubles with my boiler, thought while it was off to change the valve, as it had been leaking by for its hydraulic test. (Its done well for some 20 years)
        The surface of the ball had lost its finish.
        So it was replaced and the engine back in steam.
        A further problem with the boiler meant it was soon back off and inspecting the regulator the seals around the ball had melted.
        Obviously not the same quality as the one before.
        So it had failed due to the exessive heat in the smokebox.
        So it looks like screwfix here I come!
        Any suggestions on thread seal as I had the devil of a problem last time?
        #230298
        Ron Hancock
          @ronhancock63652
          Hi I have been told to use copper Silicone high heat not ran mine yet but hope it helps got mine of Ebay
          #230360
          Keith Spence
            @keithspence94888
            Thanks Ron but can you confirm what you bought as Ebay had nothing listed under Copper Silicone High Heat.
            #230447
            Ron Hancock
              @ronhancock63652
              Abro ultra plus copper super high heat-temp gasket maker hope that helps
              Ron
            Home › Forums › Locomotives › Topics
