Evolution rage2
Evolution rage2
Home › Forums › The Tea Room › Evolution rage2
  • #502037
    Ian Hewson
      @ianhewson99641
      Last year I moved house and sold nearly all of my workshop equipment as we were downsizing.
      I have now got withdrawal symptoms and have bought a mini lathe and mill which fit in to my garden shed. As space is limited I was considering the evolution rage 2 chop saw for cutting metal.
      Has anyone got any information on these saws regarding performance and noise levels please?
      #36124
      Ian Hewson
        @ianhewson99641
        #502039
        Frances IoM
          @francesiom58905
          for a brief period until I became wiser and bought a band saw I used one – throws red hot bits of shard a long distance – wouldn’t like to try it in a small shed but ok throwing to into a garden.
          Handles mild steel fine but don’t try stainless – it hasn’t now been used for some time as a cheap bandsaw handles all except SS – the small SS rods etc are cut with a small angle grinder
          Edited By Frances IoM on 18/10/2020 17:58:14
          #502042
          Ian Hewson
            @ianhewson99641
            Thanks for the fast reply Frances, that is the kind of info I am looking for, online videos are all very well, but someone with practical experience of the for our kind of use is invaluable.
            Ian
            #502046
            Alan Waddington 2
              @alanwaddington2
              Second what Frances said, also bloody noisy, so earmuffs a faceshield, hat and scarf necessary in a confined space.
              Got one here you can have for nothing if you can pick it up or arrange collection
              #502047
              Speedy Builder5
                @speedybuilder5
                as Frances said, excellent for softer steels, don't try rebar and high tensile steels as blade won't last long, non ferrous are good but do wear all protective goggles etc. I don't have a bandsaw, so its the Rage for me (on my 2nd blade).
                #502053
                Ady1
                  @ady1
                  Just get a 125mm discs angle grinder, which cuts everything
                  I use blue spot 1mm stainless discs
                  Aldi may still have a few left in their stores, their online stock sold out fast
                  #502054
                  Alan Waddington 2
                    @alanwaddington2
                    Posted by Ady1 on 18/10/2020 18:47:04:
                    Not so good on Ally
                    #502055
                    Ian Hewson
                      @ianhewson99641
                      Hi guys
                      Thanks for all the reply’s, think that I won’t be getting one after your advice, noise would be a consideration, just got a nice set of quiet neighbours.
                      Thanks for your generous offer Alan, much appreciated, but it looks like I will be using the old Armstrong hacksaw for now.
                      #502064
                      Ady1
                        @ady1
                        Ally needs a dead straight cut, I use a bench angle grinder to do bar up to 50mm
                        And don't breathe the dust as it flies about…
                        #502071
                        Maurice Taylor
                          @mauricetaylor82093
                          Just bought one second hand from my neighbour .One blade cuts steel and wood.Mounted it on a piece of old kitchen worktop screwed to a length of 4 x 2. Then it clamps into a work mate. Always used outside ,too messy to use in shed.I think it’s a very good machine.Regarding noise, all cutting machines make it.
                          Maurice
                          #502073
                          Rod Renshaw
                            @rodrenshaw28584
                            i bought one of the £150.00 Aldi band saws and have been very pleased with it. It's fairly quiet, does not throw swarf about and it has variable speed for different materials. I have bought spare blades from Tuff saws but not yet had the replace the original blade. There was at least one thread on the forum on these saws, about 2 years ago. it was an on line -only offer, not sure if they still do them.
                            Rod
                            #502075
                            Stuart Smith 5
                              @stuartsmith5
                              I have had a Rage saw for a while. The same blade cuts wood and metal, but I have used it almost exclusively for wood. It is noisy on metal and creates a shower of sparks . I have recently used it with a diamond blade to cut some block paving blocks which worked well.
                              I bought an Aldi ‘portable’ bandsaw earlier this year and have found it good. The vice is not particularly good and the cut on mine is not quite square, but overall I am happy with it. It is available at the moment online only at £160.
                              I would recommend a bandsaw over a Rage saw if you only want to cut metal.
                              Stuart
                              Edited By Stuart Smith 5 on 18/10/2020 21:13:26
                              #502093
                              Dr. MC Black
                                @dr-mcblack73214
                                I have one of these chop saws.
                                I was considering buying one from either Toolstation or Screwfix but contacted the company fro “Pre-sales information” and discovered that I could buy an almost new manufacturer refurbished model at around half the price.
                                When I opened the box, it looked brand new.
                                It does make a mess when cutting steel bar – but nothing that my Nil&isk can’t handle.
                                MC
                                #502096
                                Paul Lousick
                                  @paullousick59116
                                  Instead of a chop saw get a small bandsaw. Much better, light weight, less mess and quieter. Do a search here on MEW, lots of articles posted.
                                  Paul.
                                  #502107
                                  Dr. MC Black
                                    @dr-mcblack73214
                                    I did consider a Bandsaw but don't have sufficient space for one in my shed-workshop.
                                    MC
                                    #502110
                                    Paul Lousick
                                      @paullousick59116
                                      Their not that big. Mine sits on top of a milk crate and can be picked up with one hand and stored away.
                                      Paul.
                                      #502113
                                      Oldiron
                                        @oldiron
                                        Posted by MC Black on 19/10/2020 09:16:05:
                                        MC
                                        I agree with Paul. My bandsaw takes up less benchtop area than my Rage2. I now only use the Rage2 for wood.
                                        regards
                                        #502129
                                        martin haysom
                                          @martinhaysom48469
                                          hated mine. blade did not last long so got a band saw quilter and safer then put a wood blade in the rage 2
                                          #502131
                                          ega
                                            @ega
                                            I have an Evolution Rage saw blade which I use occasionally in my radial arm saw, for example for cutting sheet metal when it works very well.
                                            The blade is well designed with neutral rake and chip limitation and, FWIW, made in Japan.
